Cinema4D 2022.1-[R10] (Previous stable) (26.03.2023)
There's e new build(R7) which targets a few fixes. Enjoy it!
- dermotfaloon
I simply dont have those options to select.
Can do aces cg renderspace but display space ONLY has ACES. Using 1.2.
How are you getting those options? Are you using 1.3 or a different C4d? (I am on 2023.1.3)
Thank you for update.
There is still problem with ImageAdjustment node - Brightness tab. These slider value ranges are totally out of scale - especially values under 0. Most of them should have range within -1 to 1
There is no way to scale Vectron object other than primitives
I don't know from which version but there is no way to drag Octane nodes to xpresso window because they stopped to show in C4D attribute window and they visible only in Octane node editor. But unfortunately there is no "window caption" to drag it to xpresso window.
I can drag only whole Octane material but not individual nodes
There is issue with vertex map when it is created while polygons are disconnected. After connecting polygons again it shows totally different than in C4D :
Scene included.
It is caused because Octane doesn't support vertex map Polygon Points mode - only point mode.
Scene included.
- vert_col.zip
- (118.29 KiB) Downloaded 147 times
There is no Vectron, SDF input for Field Shape :
- jayroth2020
@SSmolak, right-click the attribute you wish to drive with Xpresso and choose "Set Driver" from the menu. This will create an Xpresso tag with the relevant information, which you can then copy/paste anywhere you need. It's described in the manual here: https://docs.otoy.com/cinema4d/UsingSet ... resso.html
Yes, I know that but old way by dragging node doesn't work. At the moment we must use workaround by creating new xpresso and copy-paste method.jayroth2020 wrote:@SSmolak, right-click the attribute you wish to drive with Xpresso and choose "Set Driver" from the menu.
you can drag from material managerSSmolak wrote:I don't know from which version but there is no way to drag Octane nodes to xpresso window because they stopped to show in C4D attribute window and they visible only in Octane node editor. But unfortunately there is no "window caption" to drag it to xpresso window.
Please stick to feature what we are supportingSSmolak wrote:There is issue with vertex map when it is created while polygons are disconnected. After connecting polygons again it shows totally different than in C4D :
Scene included.
