This is a repost jun in case. Please fix it. We cannot render.
"Now version 13.13 and up will not update vdb even though it set as octane proxy
This is what you fixed in the version 13.13 "Fixed Octane Volume unnecessary updates when changing the node transform"
i wonder this is the reason now linked volumes wont update now. Can you return it back to how it was or update during rendering at least."
Linked vdb volumes won't update
C. RAM Capacity (i.e. 6 GB)
- vdb update.zip
- (16.91 MiB) Downloaded 125 times
- neonZorglub
Hi coilbook,coilbook wrote:This is a repost jun in case. Please fix it. We cannot render.
This was indeed part of the optimization to improve the point display in max viewport, with a bad side effect, sorry about this.
This will be fixed in the next release.
Thanks for the sample!
neonZorglub wrote:Hi coilbook,coilbook wrote:This is a repost jun in case. Please fix it. We cannot render.
Thank you.
Can you please look into itoo and limited view through camera not updating. HEre are itoo forum posts. They say it works but you can clearly see that sometimes limited view is not updating with octane. I think you have to login in itoo to see images. Not sure if clipping settings are wrong in itoo tab Thank you
https://forum.itoosoft.com/forest-pro-( ... mera-view/
https://forum.itoosoft.com/forest-pro-( ... -updating/
