Cinema4D 2022.1-[R10] (Previous stable) (26.03.2023)
freeter_e wrote:feedback:
objecttag to null object, subdivision level modified, live viewer not update
must click "send your scene and restart new render"
version: 2022.1-[R5]
It has to be like that because of performance reasons and limitations of update system.
SSmolak
It has problem with updating scene nodes, capsules too :
oct_nodes_update.zip
(1.64 MiB) Downloaded 111 times
SSmolak wrote:It has problem with updating scene nodes, capsules too :
Same answer will go to you also
freeter_e
ok, thank you
freeter_e
modify material type, some problem.
I didn't know this is octane setting or bug?
2023-01-23.mp4
(4.61 MiB) Downloaded 2037 times
Kalua
Hi, Aoktar
Is it normal to have the "Chaos node" to behave very differently if placed before or after a "Color Correction" nodde?
Don't remember seeing this difference on earlier builds. On Standalone we don't see this problem.
Please see pitures.
C4D OK
C4D OK
C4D not OK
C4D not OK
OK on SA 1
OK on SA 1
OK on SA 2
OK on SA 2
C4D 2025.1.1 Octane v1.9.3 // Octane SA 2026.3, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
SSmolak
Is there chance to add input, working node pin to color correction - mask ? At the moment simple masking of texture corrections needs to use more nodes. This mask correction in color correction node without input is useless.
SSmolak
Material viewport display issue using standard material and metalness parameter :
If object doesn't have uv map it display fine in uv material projection. But other projections flat, cubic still have this issue.
SSmolak wrote:Material viewport display issue using standard material and metalness parameter :
Don't know what you're assuming here but there's not any capability to write/develop the shaders for viewport materials. We just render a flat plane and apply as diffuse. Maxon never provided any example or sources for doing something better.
SSmolak
aoktar wrote: Don't know what you're assuming here but there's not any capability to write/develop the shaders for viewport materials.
I'm not report that this should simulate metallic material but it lose color in viewport - materials are totally black. It's better to have plain color than black.
Strange that I didn't noticed this before but in all other material types, universal... there is the same view issue :
Problem is more noticeable if we have one large metallic material like this :
All building is black in viewport because of metallic panels.
Return to “Releases”
