Sometimes when I export a scene to standalone I can't find scene render node.
No problem to batch render, but I can't make any change for the render as I can't select the node...
Any clue ?
Export to standalone, can't find scene render node
@elsksa
Hi, I'm not very familiar with Octane standalone. I'm very frighten with its UI because I use to clic, scroll,... a lot as in Max and in Octane UI I make a ot of unwanted things
In scene outliner I can't find target render node in some export.
If I clic on Target render node in node inspector, I should have the node selected ?
- paride4331
Hi HHbomb,
I hope it helps.
https://docs.otoy.com/StandaloneH_STA/S ... ewport.htm
https://docs.otoy.com/StandaloneH_STA/S ... pector.htm
https://docs.otoy.com/StandaloneH_STA/S ... Editor.htm
https://docs.otoy.com/StandaloneH_STA/S ... tliner.htm
I hope it helps.
@elsksa
Thanks but target node isn't present in this window.
As soon I finish my project I'll insvestigate in this problem ...
Hi, as I don't like to say something wrong, I checked my octane files and found every time a scene render target...
I suspect my problem to be from using different versions of the software or before 11/28 update ( ??? ) and for my render job I needed to have both computers to be on same version.
Now it seems to be ok, except that buttons in the Node inspector like "Selects the render target node and shows it in the node inspector" works only if the Scene render target had been selected in scene outliner.
All is fine, I'm happy !
