Hi
I am having issues in Blender Octane. Most of everything is working ok although it does seem more complicated than the version in C4D.
However the one issue I am having is that Denoising doesn't seem to work . I have followed the instructions for this and the viewport just stays grey. If I render with Denoiser, the render just hangs.
The solution is to save as an Orbx and do the denoising in Standalone.
Just want to know if other people are having this issue when using Blender Octane on Mac M1 machines
Richard
Denoiser not working in Blender Octane
You might want to check and make sure that you have a GPU set for rendering the denoise pass. It's in the Octane server settings. If you have the denoise pass setup than that is the only thing I can think of that might not be correct?
- RegSquires
Thanks. I looked at the settings and denoiser was checked, I’m just not sure how compatible this version of Blender is with M1 Max Apple computers
This is for Windows, but I would think it works the same way in all versions?
https://www.youtube.com/watch?v=DRzHw8wAy_o
