Hi Richard,
ok, last try, can you install the following version?
https://render.otoy.com/customerdownloa ... OSX_m1.zip
ciao,
Beppe
- RegSquires
@bepeg4d I installed and restarted my MacBook. I started using Cinema and all was fine and then it crashed. I have included the bugreports folder which also includes recent crashes. This is not my imagination and not a bad install. I hope you can shed some light on this
all the best
Richard
all the best
Richard
- _bugreports.zip
- (8.36 MiB) Downloaded 692 times
Thanks Richard for sharing the logs.RegSquires wrote:@bepeg4d I installed and restarted my MacBook. I started using Cinema and all was fine and then it crashed. I have included the bugreports folder which also includes recent crashes. This is not my imagination and not a bad install. I hope you can shed some light on this
all the best
Richard
The crash seems not Octane related, but macOS related: Did you have other applications running?
The only thing I can see is that you are still in Monterey, while I'm working in Ventura
ciao,
Beppe
P.S. I'm writing you via Private Message with some details.
- RegSquires
So this afternoon, I started using Octane and I couldn't believe I didn't get a crash. I thought the gremlins had gone and I was very happy. Unfortunately after dinner I went back in and C4D crashed. Aaaaargh. Very frustrating
I believe Beppe is on it although he is super busy one everything else. I don't think I am alone in my frustrations
regards
Richard
regards
Richard
Welcome to the club, man!Re: NEW: Octane X - is finally here! [MEGA FAQ THREAD]
Post by RegSquires » Wed Dec 21, 2022 8:18 am
regards
Richard
Although Octane is more stable during editing textures and nodes, it tends still to crash on every turn. Edit object scale - crash. Changing lights rotation - crash. Turning on/off layers - crash … and so on and on on. Even importing rigged character made my C4D r2023 crash. Previously most frustrating thing was texturing. When I got through it, the rest was more or less stable. During past three weeks with one of my projects, I have spent at least one day on restarting C4D and learned that you have to save your project after every little edit.
- oTTo-supertramp
You are not alone with this problem.
I created the simplest scene with a sphere and one light source. When you close Live Viewer, c4d just stops responding and you have to reboot.
In the window - Octane Settings, changing the compatibility settings also does not give any result.
[youtube]https://youtu.be/oXg9GZYF-aM[/youtube]
Unfortunately I am crashing again as well after reinstalling per my previous post. It seems to only happen if I close the Live Viewer window, then I get the spinning beach ball and have to force quit. Going back to the Nov 25 build one more time to see if I have any better luck.
What happens if you add the Live View window to a custom C4D layout and save it?
Can you change layout without the spinning beach ball?
ciao,
Beppe
ciao,
Beppe
