is a bright filament lamp possible?
andi
I'm currently working on a scene where the only main lightsource is a very bright filament lamp.
The filament is very small but should emit a lot of light (like in the real world).
For the filament i made of course a small mesh that functions as a blackbody emitter. So far so good.
The problem is now, that i can't get this small mesh bright enough in octane.
The maximum power of 100 at the octane blackbody option is far to low.
Is there something i have overseen? Is there a possibility to get it brighter?
In the scene i'm working on, i can't fake anything or at least it would be very sad if i would have to.
The clue of the scene should be, that everything is physically correct.
So for the scene i need a point-like light source and i liked the idea, to build it like in the real world with a filament as a blackbody emitter.
1. Question:
Has someone an idea? Or am i maybe just to stupid and this is not a problem at all? Did i oversee something?
2. Question:
I also tried to get a satisfying result by tweaking the camera options (iso and gamma) to brighten the picture, but i got to much noise at 64k samples/px. Is it possible to increase the maximum of 64k samples/px?
thanks in advance
andi
Software: | Octane 2.52 | Blender 2.5 | Linux Mint 11 64bit |
Hardware: | CPU Intel Core2 Duo E6750 2.66 GHz | RAM 4GB | Videocard GeForce GT 430 |
Qtoken
Hi Andi,
From what I understand, from other similar posts,
For more information see: http://www.refractivesoftware.com/forum ... f=9&t=4176
The problem (simplified),
Tracing rays from the camera's view to that tiny, thin emmitter like a fillament usually miss the actual light source, expecially those that have already bounced off a surface or two.
The Current Fix (That I know of)
Create a "shell" around your bulb, such as copy and scale the glass a few mm out from the surface. Then in Octane use that shell for the actual light emitter and set its opacity to completely transparent, making it invisible.
The Future Fix - The new Octane Rendering Kernel thats been talked about with its bi-directional ray tracing. YAY!
Win7 x64 - i7 920 - 6GB RAM - GTX470 - Blender - 3DCoat - Octane.
andi
Thanks for the answer Qtoken!
I was thinking about if Octane is bidirectional. I thought it should be cause it's so fast. But on the other hand it explains the difficulty’s I have with small light sources.
But anyway, it should be possible to solve this problem with more samples/pixel. Sadly 64000 samples/pixel is the highest value one can choose :(
Or is there a possibility to render with more samples? Does anyone know?
Will bidirectional path-tracing be in the next version?
Andi
