juanjgon wrote:ThomasHelzle wrote:Question: What does the IPR do when it shows "Converting gdp" in the commandline of Houdini?
I get constant crashes in a scene all of a sudden and don't know what this means so can't debug it...
The IPR itself shows that it's loading a temp packaged GEO object at that moment - is it possible that such a temp geo is getting corrupted? I couldn't find the file or folder on my harddrives.
I also sometimes got a hard crash when changing the diameter of a torus light while using the (old) IPR.
Thanks for the updates, other than the above crashes I get really good results here from the RC1.
Windows 10, 1 RTX 2080 TI, Driver version 526.98, Houdini 19.5.435
Cheers,
Tom
Can you please share an example scene with this problem to take a look at it here?
Sorry for the late reply, I don't get notifications here.
Not in this case, it's a huge file with a lot of dependencies and the problem is specific to it.
- The crash from the torus light started after we added the fifth or sixth one, had the IPR open while adjusting the parameters of the torus geometry.
- The other hangup/crash started after we fiddled with a volume layers position.
If you can't provide any guidance, I'll probably have to hide/remove scene elements one by one...
Thanks anyway...
Cheers,
Tom
