RegSquires
bepeg4d wrote:New Standalone OctaneX 2022.1-RC2 for Apple Silicon M1/M2, with full AI Denoiser support, also for Volumes:
Plugins will follow asap.
Happy Mac GPU rendering!
ciao,
Beppe
This is super fast on my M1 MacBook Pro especially the DeNoiser which is actually usable now. I was excited to output an ORBX from C4D but unfortunately this does not work as expected. I did a simulation of falling spheres in a cloner. This sim was baked to keyframes and textured and lit very simply in the Octane plugin in C4D. However some of the spheres get cut up weirdly as is shown in the attached screen shots. Orbx file attached
obxtest2.orbx
(728.33 KiB) Downloaded 587 times
Hi RegSquires,
thanks for the positive Standalone feedback :D
About c4d scene exported in .orbx, could you share the c4d scene with me, even via Private message?
ciao,
Beppe
RegSquires
bepeg4d wrote:Hi RegSquires,
ciao,
Beppe
I’ll try and recreate tomorrow and send it through. It’s my bedtime here in Australia. Thanks for getting back
RegSquires
ciao,
Beppe
I tried to recreate the scene this morning and I can't get the issue to replicate. Which is a good thing. Perhaps it was intersecting geometry at the start. Not sure. But It seems it works as expected, which is actually really good news
New OctaneX version 2022.1-RC2 for mac with M1/M2 chip, with new Pyro, full AI Denoiser, and C4D Noise/Gradient support:
viewtopic.php?f=85&t=80781
ciao,
Beppe
@RegSquires: Great!
New c4doctane 2022.1-RC3 for M1/M2 only, next version will be the stable version:
viewtopic.php?f=85&t=80809
ciao,
Beppe
M130
bepeg4d wrote:New c4doctane 2022.1-RC3 for M1/M2 only, next version will be the stable version:
Don't forget to fix the environment tag rotation bug. ;)
olavalvons
Hey, unfortunately the pr 14 version for intel and c4d 2023 is not useable.
It keeps crashing all the time no matter what i want to do. In this example i was just trying to add a projection node to the octane noise. I‘m on an imac 27 with monterey 12.5 and a egpu.
R25 with Octane is working fine tough.
Thanks in advance
Here‘s the log.
[2022-11-25 08:42:34][1] Register OctaneLive
[2022-11-25 08:42:34][0] Loaded Octane DLL:Octane X Studio PR14 version:10000308 SDK:PR14
[2022-11-25 08:42:34][0] Octane X for Cinema 4D PR14 built for:20230 C4D vers:2023100
[2022-11-25 08:42:34][0] C4D:2023100 comp:[iMac von Mitch] OS:[OS X 64 BIT] macOS: Version 12.5 (Build 21G72) versType:10
[2022-11-25 08:42:34][0] CPU:[GenuineIntel, stepping 5, model 5, instruction family 6] speed:3.8 GHz numOfCpu:16Ht
[2022-11-25 08:42:34][0] Plugins:[addons advanced_render alembic archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_emulation c4d_viewport_render c4dOctane-R27 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair i_skp interop interop_forger io_forger io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor2 objects onlineupdater pbd_simulations physx_hybrid projectassetinspector python redshift relaxuv scenemanager2 sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking_particles tool_system_hybrid tpoperators usd uvviewport volumes xpressocore xtensions redshift4c4d ]
[2022-11-25 08:42:34][1] LoadOslScripts()
[2022-11-25 08:42:34][0] Loaded 89 osl scripts from dir:/Applications/Maxon Cinema 4D 2023/plugins/octane/res/osl_scripts
[2022-11-25 08:42:34][1] LoadCustomLuts()
[2022-11-25 08:42:38][1] <markMaterials>
[2022-11-25 08:42:42][1] <markMaterials>
[2022-11-25 08:42:43][1] <markMaterials>
[2022-11-25 08:42:44][1] <markMaterials>
[2022-11-25 08:42:45][1] <markMaterials>
[2022-11-25 08:42:46][1] <markMaterials>
[2022-11-25 08:42:47][1] <markMaterials>
[2022-11-25 08:42:48][1] <markMaterials>
[2022-11-25 08:42:48][1] initOctaneLive()
[2022-11-25 08:42:48][1] Init OctaneLive...[2022-11-25 08:42:51][1] Plugin initialized.[2022-11-25 08:42:51][1] Plugin activation...[2022-11-25 08:42:55][1] Plugin activation OK.[2022-11-25 08:42:55][1] Activation time=6.704 sec.
[2022-11-25 08:42:55][0] readDeviceSettings E:0 P:0 T:0 D:
[2022-11-25 08:42:55][0] VRAM used/free/max:0Kb/15.984Gb/15.984Gb Out-of-core used:0Kb RAM used:24.884Gb total:32Gb OpenGL free/total:0/0
[2022-11-25 08:42:55][1] Device:0 [AMD Radeon RX 6800 XT]<Dis>[][0] Memory used/free/total:0Kb/15.984Gb/15.984Gb outOfCoreMem:0Kb p2pBytesUsed:0 runtimeDataSize:0Kb
[2022-11-25 08:42:55][1] Device:1 [AMD Radeon Pro 5700]<Dis>[][0] Memory used/free/total:0Kb/7.984Gb/7.984Gb outOfCoreMem:0Kb p2pBytesUsed:0 runtimeDataSize:0Kb
[2022-11-25 08:42:55][0] restoreDeviceStates status:2
[2022-11-25 08:42:55][0] setDevicesActivity E:0 P:0 T:0 D:
[2022-11-25 08:42:55][0] save
[2022-11-25 08:42:55][1] convert mat:[OctUniversal1] tip:1029501
[2022-11-25 08:42:55][1] generate material:OctUniversal1[2022-11-25 08:42:55][1] LoadOslScripts()
[2022-11-25 08:42:55][0] AllDevicesOff
[2022-11-25 08:42:55][1] >> ProcessUpdate(flags=M cAsyn=0 dDelay=0
[2022-11-25 08:42:55][1] <markMaterials>
[2022-11-25 08:42:55][1] generate material:OctUniversal1[2022-11-25 08:42:56][0] AllDevicesOff
[2022-11-25 08:42:56][0] restoreDeviceStates status:2
[2022-11-25 08:42:56][0] setDevicesActivity E:0 P:0 T:0 D:
[2022-11-25 08:42:56][0] save
OctaneRender 2022.1 stable is out!
You can find the release notes, and Standalone download link for M1/M2 here:
viewtopic.php?f=24&t=80814
ciao,
Beppe
New OctaneRender® for Cinema4D Studio+ 2022.1 (Latest stable) already available as Studio+ version for M1/M2!
Enjoy it!
viewtopic.php?f=85&t=80831
ciao,
Beppe
