Recamara
roco
i add image with another changes in the curtain material
regards
Windows xp64 Bits, Intel i7-920, 1 GeForce GTX470 1280 mb V2+1 Gf 8600 512 mb for DISPLAY only, 12 Gb Ram DDR3 1867 Mhz, Heat Heatsink H50 water cooling, Power Supply 750 Watts, HAF 932 Full Tower, 4 Fans Cooler Master 120 mm, 28 Amp. 2600 RPM
radiance
You should try to use diffuse transmission for the cloth (there's a cloth material in the livedb),
it will look much better, currently it's too transparent...
Radiance
roco
thank you for the tip radiance i will test and i will upload again the image with materials live db
regards
roco
excuse me radiance, do you know about link video tutorial how i can do to put an material of livedb into my scene in octanerender ?
thank you if you can rply this comment
regards
msciwiarski
Just drag it from liveDB to the viewport or graph editor and link it to the material in object.
cheers
Michal
Hardware: Core2Quad Q9650, Asus P5Q Deluxe, GeForce GTX580
Software: Windows 7 Ultimate x64, Sketchup 8, Blender 2.56, Octane 2.4
roco
i think so the problem is the opacity, becouse when i do click 1 to .95 the background looks a blue color
i add image with the material taked in livedb and puting in the scene
roco
i add new image is the same result i don't know how i can do a realistic curtain without blue background
maybe need fix the detail in the opacity option
regards
