Hey Guys,
I just realised that the Octane Tag on a Matrix-Object doesn`t recognize the Matrices as Particles like Redshift does
so that Octane would render them. Does anybody know if this is going to be implemented?
Matrix Object / Octane Tag like in RS
What happens when you put it to scatter object as distribution input?
- eyelovemotion
hi aoktar, the Chief himself- coolaoktar wrote:What happens when you put it to scatter object as distribution input?
yes- I tried that. And it works. But unfortunately not for animations
even if I cache the matrix anination with mograph cache. Or am I missing something?
Update problem? Scatter needs to detect changes for animation, otherwise will be static
- eyelovemotion
Yes- when I update the render it is correct.
but when I try to render my animation, even if mograph / matrix object are cached before
it will not be rendered in picture viewer.
it stays static from the first frame. scatter-clones are not moving with the animated matrices.
Drop a sample scene to let me test iteyelovemotion wrote:Yes- when I update the render it is correct.
