Dept of Field noise
almsdesign
Hi, all!
I have an issue that is coming with me from project to project and I don’t know how to solve it. The issue is a noisy blur when you have camera depth of field (see attached, denoiser is turned on). The more depth of field I have, the more noise it has, without the depth of field image is very clean.
I tried all I thought can help and all I found here, and the result is the same…
So, here is the list of things I tried:
1. Increase samples. I had 900 samples and tried to increase them to 6000. No changes
2. Adaptive sampling, not a big difference, little better when min samples are lower.
3. Filter size, hot pixel removal also didn’t help.
4. 2x dimensions and then rescale it
5. Direct lightning and Path tracing gave the same result (PMC is taking too much time, I want to do an animation, so 12 minutes per frame is really painful)
I am rendering in 16-bit, EXR Octane. And this situation really upsets me, because I absolutely love this render, am I doing something wrong? I see a lot of octane artists with a beautiful clean depth of field and I don’t see many topics with this problem in the forum. Adding dof in post is not an option, it gives me a bad result, much worse than in octane.
I would be very grateful for ANY suggestions or tips, thank you all
Noise with lower depth of field
Noise with high depth of field
My settings
My settings
almsdesign
elsksa wrote:Hi,
Usually, it's often the following:
• Plausible shading (especially specular reflection always requiring a minimum amount of roughness, and refraction)
• Appropriate lighting (avoiding extreme "intensity values")
• Tweaking Adaptive Sampling (requires the "Noise" AOV, otherwise it's hit or miss).
Worth mentioning that Parallel Samples can be pushed to maximum (32) if VRAM allows.
Secondly, Caustics Blur would often be also maxed out when caustics (reflective or refractive) are not needed. It immensely help, depending on the scene.
Most of it has been grouped into this page (for further details and as a "handy reminder"). An other shameless plug, I've recently posted about the Universal Camera.
DoF in Octane will certainly be superior to doing it in post. It shouldn't be a problem from what I see on the provided screenshots.
Hello elsksa, thank you so much for the answer. I will study in detail what you sent and try to apply it in the scene and post the results here.
p.s.
I'm constantly researching this forum and seeing your answers, I want to say that they are just super professional and interesting!!
almsdesign
elsksa wrote:Hi,
I have tried changing the settings and it seems to me that result is the same. I have tried different materials, with or without roughness (also with very little roughness). The lighting in the scene is very regular, just a simple hdri with very little power, and some area lights also with a small power (because of the size of the drone, it is like 10 cm). Adaptive sampling I also changed according to the noise map.
I also changed parallel samples to maximum and maxed out Caustic Blur. You can see my updated settings attached.
Maybe I'm wrong somewhere, but so far everything I've tried does not bring any changes. Anyway I'm very grateful to any advices
james_conkle
That’s looking pretty clean but yes DoF can be quite expensive. Your settings look good I would suggest using the denoiser as well and you could blend between the denoised image and the raw beauty so you can recover fine details. Otherwise I sometimes need 8-10k+ samples in extreme conditions.
The only other thing might be scene scale/ray epsilon . If my scene is super small or big I rarely but sometimes notice an improvement by adjusting the ray epsilon accordingly.
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
almsdesign
james_conkle wrote:That’s looking pretty clean but yes DoF can be quite expensive. Your settings look good I would suggest using the denoiser as well and you could blend between the denoised image and the raw beauty so you can recover fine details. Otherwise I sometimes need 8-10k+ samples in extreme conditions.
Yes, I have the denoiser also turned on, it is doing a good job on not blurry parts, but with blurred dof parts it is not doing anything. I tried to adjust ray epsilon, but it seems that in this case, it does not solve the problem. May I'm too demanding and this is a normal condition for dof?
Thank you for your answer
almsdesign
Changing the amount of samples is not doing much difference. Also, I set adaptive sampling according to noise map, so I think this parameter is right.
I'm sorry if I bored you, I just have this problem often and I would like to understand if I can do something about it
almsdesign
elsksa wrote:It looks "clean enough". It's either a matter of subtle tweaking or gentle denoising.
almsdesign wrote:I set adaptive sampling according to noise map, so I think this parameter is right.
In case of uncertainty: https://youtu.be/dHTnaYjj3g4
almsdesign wrote: I'm sorry if I bored you, I just have this problem often and I would like to understand if I can do something about it
You are not bothering us at all. That is what this forum is for.
Slightly off topic: this is highly recommended.
Thanks for all advices and articles, it is definitely useful to understand the main principles of rendering in 3d. I will try to still play around with the settings and delve into the topic, if I manage to change something, I will publish the result here. Maybe this will help someone with a similar problem
jayroth2020
Can we see the HDRI you are using?
almsdesign
jayroth2020 wrote:Can we see the HDRI you are using?
I'm using this one from polyhaven in 4k resolution https://polyhaven.com/a/studio_small_09
almsdesign
As a side note, it could easily be all done without an HDRI.
Studio lighting is actually best without it. Much more lighting and sampling control. It is night and day.
If you are not in a rush, I could guide you to reproduce a similar lighting setup in "3D" (without an HDRI).
No, I'm not using bokeh map.
In this scene I'm using hdri for reflections mostly, but also to brighten dark places a little. But I really want to improve my skills and make more professional renders, so I will be really grateful if you can do this!! :)
