Stick noise to deformable mesh
coilbook
Does anyone know how to bake octane noise to deformable mesh? I have a mix material with green and brown and octane noise as a mask. But even using XYZ to UVW projection wont make noise stick to deformable mesh. I attached the video. Thank you
sticky noise.MOV
(783.58 KiB) Downloaded 912 times
paride4331
Hi coilbook,
If I understood your issue correctly you can fix it setting coordinate space to "object space".
Return to “Autodesk 3Ds Max”
