What is Compiling Mesh/voxelizing all about?
Hi there, can someone help me out with this? I'm trying to get to understand what is compiling mesh/ voxelizing all about, why is it a stage at which octane sometimes crashes and sometimes not, and what to do to avoid this issue? Are there any dos and donts when exporting to obj that you shold bear in mind? I have some very simple projects (in terms of number of polygons) that when loaded cause octane to crash at voxelizing stage, but at the same time some other much more complicated projects load properly..so I'm quite confused with this.. I tried to swap cuda drivers to older versions but it doesn't seem to make any difference. I work with blender if that's relevant, would be grateful for some advice.
- mib2berlin
Most of the times it is a export problem. Du you use the blender export script?
There in the advanced settings are the export settings, take a look to this.
Or take a look to the manual.
Cheers mib
Cheers mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
Excellent, that was it I guess, I used the script and it went through voxelizing smoothly! Previously I just selected meshes and exported them to obj without using the script. Don't know where the difference lies, but it's working so I'm happy. Thanks!:)mib2berlin wrote:Most of the times it is a export problem. Du you use the blender export script?
It's usually because you're process runs out of memory.
If you're running a 32bit operating system you have a low amount of memory per process available, in practice no more than 1.2-1.4GB.
As octane needs to build some heavy voxel data to accelerate rendering on the GPU it's usually not enough for large scenes.
Installing a 64bit OS removes this limit.
Radiance
Radiance
I would recommend to anyone that uses 32 bit OS in 3d programs to switch over to 64. It makes a huge difference in performance, and the ability to use more than 4GB of ram can't be bad. I've heard some complain that they can't afford to -- which I don't understand, as it's not more expensive -- but the time lost to lack of performance costs more money in the long term if you're a professional.
Not referring to the original poster, just a general comment.
Ryzen 5950x
128GB Ram
RTX 3070 x 3
128GB Ram
RTX 3070 x 3
