hyde44 wrote:Hi, its strange with this version , i've some problem to render in Photon tracing mode , the sampling get stuck before the end, so it didn't save and there's a weird different count of samples between the bottom stamp and the top counter ... I'm with houdini 19.0.589
luminouspowerhouse wrote:Juanjo, changing any parameters under IMAGER (in Octane RenderTarget), like ocioView, adding LUT, etc - doesn't do any changes in IPR, even with full scene reload.
does yours work as expected?
juanjgon wrote:luminouspowerhouse wrote:Juanjo, changing any parameters under IMAGER (in Octane RenderTarget), like ocioView, adding LUT, etc - doesn't do any changes in IPR, even with full scene reload.
Here everything seems to work as expected, at least with the upcoming XB3 core libs. Can you please check this problem again once we release the new 2022.1 XB3 plugin builds (that should be available around next week)?
shishkovdima wrote:Houdini 19.5.303, Octane Light doesn't seem to work. Some textures are missing. This is just the default settings with increased intensity.
Is anyone else getting the same issue?
juanjgon wrote:shishkovdima wrote:Houdini 19.5.303, Octane Light doesn't seem to work. Some textures are missing. This is just the default settings with increased intensity.
Do you still have the same problem with the just released 2022.1.0.2 XB3 build?
