OctaneRender® 2022.1 XB 3
john_otoy
coilbook wrote:There is still a pure firefly moving noise when a light hits a specular material and then reflects in the another specular material. I think nothing was ever done about it since octane was created. Maybe you can implement some kind of cheat to solve it? Thanks
Can you provide a simplified ORBX for us to look at the issue? I've PMed you.
J.C
bepeg4d wrote:
J.C wrote:When toggling realtime button rendering the rendering goes 150% slower.
please note that Real Time works only with 1x GPU.
So if you have a multi GPU machine, this is expected.
ciao,
Beppe
There is no speed difference when it is on or off. The render times are the same using 1x GPU.
System – Windows 11
coilbook
Can we please get AUTO sampling rate for lights. So if my light sampling ratio is not correct and some lights have noise the system automatically adds more sampling rate values.
I think sampling rate is wrong. Having hundreds of lights in the scene, checking why some are noiser than others, creating balance between them is a pain. The system should see noise and auto adjust sampling rates to noisier lights
john_otoy
coilbook wrote:Can we please get AUTO sampling rate for lights. So if my light sampling ratio is not correct and some lights have noise the system automatically adds more sampling rate values.
Have you tried enabling kernel > AI light, then setting all your light's sampling rate back to a default of 1.0?
coilbook
I'll try. I thought AI was an additional feature and usually it increases render time a lot like a denoiser.
coilbook
By the way, AI denoises octane light excellent but mesh light texture never gets denoised. IF you make a scene where one light is octane light and another light is mesh texture you will see mesh texture noisy
coilbook
Another problem that was never solved (Chaos solved it) Please lock dirt to a single mesh or make mesh that touches the dirt mesh not leave a dirt mark (exclude from leaving a dirt mark)
john_otoy
coilbook wrote:Another problem that was never solved (Chaos solved it) Please lock dirt to a single mesh or make mesh that touches the dirt mesh not leave a dirt mark (exclude from leaving a dirt mark)
If I'm understanding you correctly, you can already do this. In the dirt node, set the "include object mode" to "Self".
You can also ignore entire objects, by disabling the object layer > dirt visibility.
Despot
Where are the new PostFX changes/additions that were promised for 2022 ? Are they still going to make it ?
Not expecting an answer from any Otoy employee here as my last two comments/questions were just ignored... ;)
J
divasoft
Despot wrote:Where are the new PostFX changes/additions that were promised for 2022 ? Are they still going to make it ?
J
It's funny, but Jules Urbach personally promised me in the comments to the post a year and a half ago that an update would be released that would introduce chromatic aberrations. I've been waiting for them for like 6 years now...
Looks like something went wrong.)
