Cinema4D version 2022.1-XB1-(R3) (Experimental) 02.06.2022
SSmolak wrote:
aoktar wrote:
SSmolak wrote:Changing Layered Material type to different one like Diffuse doesn't work. Only way is to create new material from scratch.
Not sure what are you showing and how you can see this menu command. It's not appearing on sub materials. And deleting/creating is not only way to change the type. See pic.
I mean Octane Composite. I thought that this menu is to convert it to something else ( not layered one ). I have old material with which is layered that now can be done using Octane UIniversal but I see that there is no way to simple convert or change it to Universal one.
Why don't you just use the "material type" for that?
SSmolak wrote:Undo doesn't work if node is still selected after changing parameter while using embedded GUI
It's not as you said. Selected GUI is avoiding to capture shortcut call for undo. Try without selecting the node, it will work. I'll fix this problem.
SSmolak
aoktar wrote: Why don't you just use the "material type" for that?
even if I change it here for sub-material it still be layered one :
I can change only sub not main.
SSmolak
Opening Octane Texture Manager in scenes with many images like 270 cause freeze or stuttering for minute.
Opening Node Editor for first time it always get 2/3 of whole screen size.
SSmolak wrote:Opening Octane Texture Manager in scenes with many images like 270 cause freeze or stuttering for minute.
Share the project and a video for the issue! It should not hold the main soft, it's not doing it in main loop.
Kalua
I can't download Enterprise R3... am I missing something?
C4D 2025.1.1 v1.8.4 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
Kalua wrote:I can't download Enterprise R3... am I missing something?
File was deleted by mistake, replaced it again. Sorry for that!
Tim_Twisted
@Aoktar
Is the Brigade kernel still planned for XB2 or RC1?
Tim_Twisted wrote:@Aoktar
I think it's for next SDK but not sure.
Tim_Twisted
aoktar wrote:I think it's for next SDK but not sure.
Thanks for the update. Really looking forward to it so hope it (or at least a beta) comes out rather soon.
Return to “Releases”
