hello
I use 3DMAX2022 with octane 2021.1.2
If I use Chinese path with VBD,my 3d max will crash.(The previous version did not have this problem)
This problem has troubled me for a long time, I hope the next version can be used in the Chinese path.
VBD file cannot support Chinese path
- neonZorglub
Hi yanchuangjie,
Thank you for reporting this issue.
I could reproduce the crash.
It should be fixed in the next release.
Sorry about this !
Sorry about this !
- yanchuangjie
HDRI texture doesn't work in Chinese path either, I'm not sure if it's a MAX issue or an octane plugin issue.
- neonZorglub
Hi yanchuangjie,yanchuangjie wrote:HDRI texture doesn't work in Chinese path either, I'm not sure if it's a MAX issue or an octane plugin issue.
The VDB filename issue is fixed in the new version: 2021.1.5 - 12.18:
viewtopic.php?f=80&t=79807
I tried a HDR filename with non ansi standard characters in the path and filename, it seems to work.
At least in Filename slot of a RGB image..
-Do you use a Chinese HDR somewhere else ?
-Could you copy/paste a Chinese filename here (not necessarily a file itself) ?
[EDIT]: all VDB and HDR filename issues should be fixed in the latest version: 2021.1.5 - 12.19:
viewtopic.php?f=80&t=79818
