benarmstrong
bepeg4d wrote:Finally, the first version of OctaneX based on latest CUDA SDK has been released today, only available for Apple Silicon M1 native, plugins will follow asap:
viewtopic.php?f=33&t=79602
ciao,
Beppe
Hi Beppe, to clarify - does this version work on mac pro with AMD GPU? Or is it solely for new M1 machines. And if the latter, will it be coming to Mac Pros with AMD GPUs? And when can we expect this? Thank you
BerezovskiyCG
ciao,
Beppe
Hey, link doesn't work :(
olavo
Hi, with all these versions I'm a bit confused.
I am still on Big Sur (Intel with egpu RX 6900XT), so for me there is now only PR11.
If I upgrade to Monterey, I can use PR14 with C4D (R23) plugin?
And what's up with PR13?
Is it wise to upgrade now or better to keep my current setup?
Olav
Hi Olav,
yes, if you upgrade to Monterey, you need to install OctaneX PR14, PR11 is only for Big Sur.
PR13 is fior Monterey too, but it has an issue with AI Denoiser and AMD GPUs, so better to go directly to PR14.
But please, firstly try to install Monterey on another partition or ssd, Apple Metal driver in Monterey is quite picky, and not all the AMD RX 6900 XT GPUs are recognized for rendering.
ciao,
Beppe
olavo
Ok many thanks for your advise Beppe!
I’ll give it a testrun first.
Olav
tlind
Any info/ETA on the plugin for S26 (Monterey) M1 native?
cheers,
Tobias
frankmci
Beppe, Jay & Co.
It might be useful and save a lot of questions if you guys make a little chart with the various OSes, hardware, and Octane combinations, showing which work and which don't. I realize that's a lot to ask for the entire line of Octane plugins, but basic Octane Render compatibility would be tremendously useful and save a lot of chatter.
JoGo23
bepeg4d wrote:Hi Frank,
ok, here it is:
ciao,
Beppe
Hi Beppe,
You also should mention that 2022.1 XB 1 only works correctly on MacOS12 and Apple GPUs.
drunknbass
is there a macOS C4D plugin compatible w/ 2022.1 available ?
