OctaneRender 2021.1 for Houdini production build 2021.1.4.2
juanjgon
This is a production release of the OctaneRender™ 2021.1 for Houdini™ plugin compiled with the Octane 2021.1.4 core. This 2021.1.4.2 release is available for the latest Houdini production builds on Windows x64 and Linux gcc6.3.1.
Houdini production builds supported by this release: 17.5.460, 18.0.597, 18.5.759, 19.0.531, 19.0.561 and 19.0.589
This build includes the first beta version of the new Qt5 IPR Window, the core of the plugin's whole new IPR system that will replace the old OpenGL IPR Window. There are still some important features missing (like camera selector, shortcuts/preferences, background image, or snapshots gallery) that will be added this year, alongside the viewport IPR rendering feature, but the core technology is ready to be tested. The new Qt5 IPR window is available for both Windows and Linux (and macOS in the future) and it can be opened as a floating window or inside a Houdini pane.
This version supports Nvidia Ampere GPUs and as a consequence, we had to drop support for old Kepler cards with a compute model < 3.5. And please make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux
New features
To learn more about the new features and improvements of OctaneRender 2021.1, please check out the 2021.1 release post
Release 2021.1.4.2 Enterprise subscription license
https://render.otoy.com/customerdownloa ... rprise.zip
Release 2021.1.4.2 Studio subscription license
https://render.otoy.com/customerdownloa ... studio.zip
Release 2021.1.4.2 Demo version license
https://render.otoy.com/plugindownloads ... 4_demo.zip
https://render.otoy.com/plugindownloads ... x_demo.zip
Standalone 2021.1.4 version for the network rendering nodes
viewtopic.php?f=24&t=79488
Release Notes
RELEASE 2021.1.4.2
* PLUGIN FEATURES AND FIXES:
- Fixed a problem in the instancing system introduced in the latest build.
- Qt5 IPR: Fixed several problems if the scene is reset or loaded while the IRP is rendering.
RELEASE 2021.1.4.1 (deprecated)
- Added H19.0.589 plugin build.
- Improved instances extraction time, which can now be up to x10 times faster!
- Qt5 IPR: Fixed the save image and export scene functions.
RELEASE 2021.1.4.0
- Added H19.0.561 plugin build.
- Qt5 IPR: Render region tool.
- Qt5 IPR: Always on top preferences option.
- New "Octane_IPR_updateSelectedObjects" hscript command.
- Fixed a minor issue in the Render Target HDA.
* OCTANE 2021.1.4 FEATURES AND FIXES:
- Added "Legacy blend mode" alpha operation and a "Force premultiply opacity" pin to the composite AOV layer node. These options allow you to reproduce the results seen in older scenes, before fixes were made in 2021.1.2.
- Small performance improvement for non-RTX ray-tracing.
- Improved startup times, especially on Linux.
- Map range output AOV node will now allow the output minimum value to be higher than the output maximum value.
- If an OctaneLive activation fails due to an interrupted Internet connection, we open a retry dialog and try again automatically after 20 seconds.
- Fixed authentication failures when more than 4 Octane processes try to authenticate on Linux. If a failure still occurs, we open a retry dialog and try again automatically after 4 seconds.
- Fixed incorrect rendering of materials that use a dirt texture as input of any of the channel manipulation textures (like Channel merger or Channel mapper).
- Fixed incorrect rendering of OSL textures that have an unconnected _sdf input.
- Fixed black pixels on materials that emit and which have an opacity of 0 or a general visibility of 0.
- Fixed incorrect values in volume Z-depth front AOV.
- Fixed render hang when you use the baking camera is a scene with displacement triangles.
- Fixed auto bump which may cause artefacts on vertex displacement materials that projections other than UV mapping.
- Fixed copy and pasting a geometric primitive, where the first change of the primitive type of the copied geometric primitive was ignored.
Happy rendering,
Your OTOY Team
juanjgon
Sorry, this build has a last-minute bug in the instancing system. I'll post a new one later today.
juanjgon
The new 2021.1.4.2 version with the instancing problems fixed is ready, and it has replaced the broken 2021.1.4.1 build that is no longer available.
Sorry for this issue and thanks for your patience,
snakeboxmedia
Do you have any examples, even just screenshots before / after of this instance speed up? Is it hardware dependant?
I have spoken to a few people now and no one seems to be seeing any difference what so ever, not that it was ever really THAT slow, but a 6-10x speed increase sounds very nice, so I'm curious in what cases this happens?
juanjgon
snakeboxmedia wrote:Do you have any examples, even just screenshots before / after of this instance speed up? Is it hardware dependant?
Check the scene attached here, for example:
viewtopic.php?f=101&t=79666
On my laptop, with the instancer configured with 3M instances, scene extraction times:
2021.1.4.0:
- Packed geo instancing: 12,2 sec.
- s@instance attr: 7,2 sec.
2021.1.4.2:
- Packed geo instancing: 5,4 sec.
- s@instance attr: < 1 sec.
mirocreative
For some reason this release is pretty crash happy for me when using the QT5 IPR. I almost always get a segmentation fault when trying to stop the IPR or even selecting lights - all fine with OpenGL IPR.
Attached a crash log, any help appreciated.
crash.scene 1 final.k_fer_37808_log.txt
(4.87 KiB) Downloaded 116 times
juanjgon
mirocreative wrote:For some reason this release is pretty crash happy for me when using the QT5 IPR. I almost always get a segmentation fault when trying to stop the IPR or even selecting lights - all fine with OpenGL IPR.
This crash seems to come from a known issue while reloading the scene that I was not able to fix yet. I'll try to work on it again asap. It is hard to predict why it happens, some systems seem prone to have this issue, while in my systems it is really hard to reproduce, so this is why I'm still investigating why it happens.
mirocreative
Thanks Juanjo, I'll use the OpenGL IPR until then, no big deal for me.
Chris.
juanjgon
mirocreative wrote: Thanks Juanjo, I'll use the OpenGL IPR until then, no big deal for me.
Chris.
This problem is not related to the Qt5 IPR. It is crash while cleaning the scene, so the same can happen with the OpenGL IPR if you reload the scene from it.
WoutTgh
Hi, just wanted to say it's really cool to see octane integrated like this with the new Qt5 IPR ! The right mouse button doesn't do anything by default, maybe that can be the render region tool ? I use it a lot, would be nice. Right click to enable, then as it is, right click outside region to disable ?
Also, is there an hscript command to pause the render ?, can't seem to find it( I like to have things mapped to hotkeys)
Return to “Releases”
