OctaneRender® for 3ds max® v2021.1.4 - 12.16
- paride4331
- neonZorglub
Hi, Alminia,Alminia wrote:Where is the "Size X" parameter in octane light ?
Thanks for reporting this issue.
You have enabled the experimental 'Expand Object Dialogs width' I guess.
There are still some issues with some objects, like this..
(This happens when you resize the dialog)
Turn it off (Preferences / User Interface / Expand Object Dialogs width), then close and reopen the dialog.
This should be fixed in the next release.
- neonZorglub
Hi samsue,samsue wrote:this is also bugging me for a long time now ... when Octane renders I can't open the Modfy panel, it doesn't load the options... the same thing with the render settings
I couldn't reproduce the UI issue.. this could be related to the 3dsMax version..
Witch version of 3dsMax are you using ?
You could try to disable Preference / User interface / Clear inactive tabs dialog ..
For the other problem, thanks for the details on the viewport mismatch ! I'll have a look.
Thanks it works !neonZorglub wrote:Hi, Alminia,Alminia wrote:Where is the "Size X" parameter in octane light ?
Also there are settings that are underlined in blue for no reason in the universal camera settings.
It returns to normal if I disable the above-mentioned option in the user interface settings.
- paride4331
Hi samsue,samsue wrote:wich node daemon version i should use for this sdk (12.16)?
https://render.otoy.com/account/downloa ... r=2021.1.4
