Hello Paride,
I have to blend two liquids in a same phoenix fd simulation, how do I set up an octane material to do that ?
Thank you in advance !
Phoenix FD liquid blend
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
- paride4331
Hi remka,
At the moment these seem to be possible solutions:
viewtopic.php?f=51&t=78391#p404302
Hello Paride,
I've tried to do what you said in this topic but I didn't managed to make it work on Phoenix FD, I guess I'm a map channel noob
I know that it's time consuming for you as Phoenix FD is not a part of 3ds max but it is a really big industry standard now.
I'm thrilled by the work done on Octane and I'm using it for almost 10 years now and I won't see myself using another plugin but that said, we still don't have a correct workflow for wetmaps or liquid blending.
- paride4331
Hi remks,
It works with 3dsMax fluid not with Phoenix.
https://knowledge.autodesk.com/support/ ... 7-htm.html
Yes I assumed that... so my question would be : is it in the development plans ?
- paride4331
Just in case someone needs this feature also, be aware that VRay GPU is not able to render a PhoenixFDGridTexture neither... everything has to go through the CPU.
