Octane not moving to next frame when rendering in Houdini.
Houdini Integrated Plugin
jpalmer593
Hello, I have previously used Octane in Cinema 4d but I am now using Octane in Houdini for the first time.
Have got my scene set up and everything looks perfect in the IPR.
Am now rendering using the ROP. I have full scene reload, as well as Output Image files, Render to Mplay and Initialize Simulation Ops checked.
When I press render sequence, it opens up the Mplay viewer and renders. The frame finishes in about 50 seconds but for some reason never finalizes the image or
moves to the next image/frame.
I have turned on Octane output to the console, and I've attached the output txt to this post.
I have no idea what to do so any help would be appreciated! Thank you!
Am using Houdini FX 18.0.597 and Octane version 2020.1.5.0 for my corresponding version of Houdini.
console.txt
(15.24 KiB) Downloaded 179 times
juanjgon
Hmm, but do you have the ROP node configured to render a frame range?
jpalmer593
I do have it configured to render a range. Still no luck!
juanjgon
Hmm, are you sure? Can you please share your scene?
Return to “Houdini”
