Hello, I just downloaded the Demo of Octane and have really been liking it so far. In my exploration I have run into an issue with the z-depth pass and was wondering if I am missing a setting. The issue is that my pass shows as solid black and white. I have fixed this by using the "Z-depth max" slider to make my pass display correctly in the live viewer though when I go to render out my multi passes (with render queue or picture viewer ) my z-depth pass ignores my tweak to z-depth max and renders out the original solid black and white z depth pass. I am rendering at 32bit and even after playing with the solid black and white version in AE I can't get the same results as I see in the Live Viewer inside C4D.
This is a workflow I would like to have down before pulling the trigger on a license, any idea what is going on?
Adam
Z Depth Pass
Hi Adam,
please, have a look here:
https://docs.otoy.com/Cinema4DH/C4DPlug ... -depth.htm
and here:
https://vimeo.com/201203670
ciao Beppe
and here:
ciao Beppe
What a mind blowing trick!
Tweak the white point !
Thanks for explaining it !!!
macpro 2 x 2.26 Quad-Core Xeon --- 6G ram --- GT120 --- OS X 10.6.4 --- Cinema4d r11.5 AR3+Vray
