Hi, I m using the latest version of Octane 2021.1.3, and latest Xp 1036.
I found a serious problem with Cached Motion blur of OpenVDB mesher. My openVDBmesher can indeed export proper Velocity data (double checked with Insydium devs), so my mesh should have motion blur even all my settings should be correct (correct me if i m wrong). When the mesher is not cached, motion blur seems works fine, but as long as I cached it then it stopped working. I tried using Cycle4D still no motion blur. a very tiny Scene file with cached file attached below. Hope everyone can help a brother out one more time. Thank u!!!
I am not sure its bug from Xp or Octane. Can some one check the motion blur problem for me?
The project file with cache in attachments and here is the video i recorded showing this problem. I dont wanna make alembic to make it work.
Thank you!
Xparticle OpenVDBmesher have buggy motion blur in Octane!
- Video Demo of this problem.mp4
- (5.33 MiB) Downloaded 875 times
- MotionBlurProblem_WithCache.zip
- (2.07 MiB) Downloaded 141 times
Thank you!
- james_conkle
- Contact:
It’s a problem in XP when using their cache tool. It doesn’t do a good job of keeping the vertex data so the best bet is to use the XP cache to cash your particle simulation and then once you setup your mesher right click on the mesher in the item manager and select the option that creates an alembic.
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
Actually you are saying enough proofs that's not an Octane problem. We just read the data from vertex tag. We cannot fix if data is broken. Also this is not first report about this problem. Please keep tracking it with xp team.
