Hello,
Sorry for my question, but I will soon need network rendering and I'm a bit confused between both…
What is the differance between both ?
I have 100 RNDR credit in RNDR and 0 RNDR credit in ORC
I would like to test both to see the differance and which is easier for me to use …
What du you recommend ?
the
cedric
ORC or RNDR ?
Cedric Uebersax, Photographer at France | http://www.cedric-u.com |
- Win11 ProArt X670E Creator 1x RTX 4090
- Win10 1909-Asus X-99 2x RTX 3090
- MacPro 7,1 Pro Vega II Duo
C4D R2023 / 2021.1.6
We have used both, ORC a bit, and RNDR quite a lot. RNDR has been a much better experience. ORC seemed like a decent first attempt, but had lots of inefficiencies that make using it for small to medium size jobs significantly more expensive than big jobs. RNDR is a newer, much more efficient, streamlined system. As I understand it, ORC will eventually be phased out/rolled into RNDR, so you might as well start there.
Thank you Frank for your answer
I will go by RNDR .
thx
cedric
I will go by RNDR .
thx
cedric
