CUDA errors all over the place :(
lalalem
Hi all,
I'm completely lost. I keep getting these errors and I have no idea why. I desperately need some help!
System:
Windows 10
Octane Enterprise 2021.1.2
Cinema 4D R25.115
NVIDIA Studio Driver 511.65
4x RTX 3090 (not Nv link).
Started logging on 18.02.22 20:21:20
OctaneRender Enterprise 2021.1.2 (11000200)
OCIO config file:C:\Users\lalalem\Downloads\aces_1.2\config.ocio loaded.
VRAM used/free/max:0Kb/24Gb/24Gb Out-of-core used:0Kb RAM used:8.97Gb total:95.847Gb OpenGL free/total:0/0
FRAME:0 fps:30
FumeFx library initialisation error!
Export materials time= 14812.937 ms
Collect objects time= 10.201 ms
Mesh creation time = 4678.346 ms.
CUDA error 2 on device 2: out of memory
-> failed to allocate device memory
device 2: disabling RTX acceleration as mesh data cannot be placed into VRAM
CUDA error 2 on device 1: out of memory
device 1: disabling RTX acceleration as mesh data cannot be placed into VRAM
CUDA error 2 on device 3: out of memory
CUDA error 2 on device -1: out of memory
-> failed to create temporary context
CUDA error 2 on device 0: out of memory
-> failed to allocate device array
denoiserThread0 : Initialization failed. Restart required
Check geometry subdivisons.
Picture viewer uses 'Render' subdivisions. But Live Viewer uses 'Editor' subdivision values.
Try to decrease 'render/editor' subdivison values.
denoiserThread2 : Initialization failed. Restart required
Unhandled exception in concurrent loop: bad allocation
device 0: invalid memory pointers passed
device 0: path tracing kernel failed
Tonemapping the all passes tm:0.035
pass [Denoised beauty] ID:43 not found...
Displaying passes in tm=0.805
Passes saved in:0.006sec.
Break rendering...
could not request a tonemap because we don't have any renderthreads available.
Tonemapping the all passes tm:0.216
Displaying passes in tm=0.383
Passes saved in:0sec.
**** RENDER FINISHED **** stat=3
Help starts with you! Begin some investigation what causes this. Remove some parts until error stops, and decide it's about some triangle count or VRAM limitations or something specific on any materials.
lalalem
Yes I know. But the scene works well in the live viewer. VRAM usage: 9Gb used. 10Gb Free. So it should work right ? But I can't render it out!
Sometimes I get this different error log :
Started logging on 18.02.22 22:46:44
VRAM used/free/max:0Kb/24Gb/24Gb Out-of-core used:0Kb RAM used:7.606Gb total:95.847Gb OpenGL free/total:0/0
Tried to access pin via an invalid ID P_SUB_TYPE (703)
Tried to access null node pin
can't read int/enum from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FF8751D70D0)
Export materials time= 14848.043 ms
Collect objects time= 13.806 ms
Mesh creation time = 3129.879 ms.
Api update time: 7.386 ms.
VRAM used/free/max:9.785Gb/11.973Gb/24Gb Out-of-core used:0Kb RAM used:38.699Gb total:95.847Gb OpenGL free/total:0/0
FRAME:0 fps:30
Export materials time= 46.564 ms
Collect objects time= 8.855 ms
Mesh creation time = 2852.656 ms.
Failed to create CUDA context
denoiserThread3 : Initialization failed. Restart required
device 2: invalid memory pointers passed
device 2: path tracing kernel failed
device 3: invalid memory pointers passed
device 3: path tracing kernel failed
Tonemapping the all passes tm:51.532
Displaying passes in tm=7.723
Passes saved in:0.274sec.
Break rendering...
Tonemapping the all passes tm:0.192
Displaying passes in tm=0.407
Only differences between LV and PV that's triangle counts when it's sent to renderer. My advice is still valid.
lalalem
Is there nothing else that could cause this, from looking at the error log ?
lalalem wrote:Is there nothing else that could cause this, from looking at the error log ?
Always there's other possibilities. Better to ask to support team, they are more used to solve these kind of issues.
lalalem
Just in case someone comes here from Google in the future : I managed to get around this problem by using NVLink. This allowed me to have way more stuff in VRAM, and I was finally able to render! Also it seems the main problem was a tennis ball hair object that I had converted to splines. There were millions of tiny spline hairs with an Octane Tag "use as hair" on it. That was the biggest problem.
