Just wondering if anyone might have a starting point for getting hdr renders from c4d to youtube via after effects? Ideally im after a super short idiots guide of what settings need to be dialled in where.
eg. Set X colour space in octane, render with 32bit buffer to openexr, disable tonemapping. Import with X interpret settings into Ae, set X project settings in AE, export from AE through media encoder with X colour space settings.
I know a lot of things I will need to do, but its one of those things where if I miss a single setting, then the whole thing will render washed out, overly saturated, with too much contrast, with banding etc. A lot of time could be spent trying to work out which step is messing things up.
As a starting point Im fairly sure I have to say goodbye to all the convenient octane tonemapping settings and instead render into a 32bit format because presumably the tonemapping will crash everything down to a 0-255 (or 0-65000 for 16bit) range. ie. clamped.
I know i'll need to do it in a format which supports 32bit, openexr being the easy choice. IS there any problem saving via c4d's save tab into c4d's openexr format or do I need to go via octane's exr exporter? I have no intention to muddy the waters with AOVs or layers just yet.
One thing I dont know is if I need to set any specific colour space settings up, rec2020, ocio and so on, or if I am safe just rendering with defaults because none of that matters in a linear space exr file?
I assume I need to set my Ae project to 32bit colour with 1.0 gamma, and interpret footage as linear light.
One of my biggest questions I guess, is whats my best bet for replacing octanes tonemapping abilities in AE? Lumetri has every setting possible but It does slow Ae down significantly. If theres a simpler effect with a few sliders then I'd love to know what I should be using. Likewise, whats the best option for Octane's "saturate to white" and "highlight compression" replacements? I do lean heavily on these when rendering tonemapped shots. Ditto for Glow, all the built in glow effects in AE seem very primitive in my experience; am I wrong or have I missed something that's half decent?
C4D -> Octane -> AE HDR -> Youtube
