How to render just the Z-Depth?
animas3D
Hi, I just cooked a long render. Unfortunately I did not set the Z-Depth right (need to move things back).
How do I just render the Z-Depth without re-rendering the RGB all over again?
Thank you!
Joe.
jayroth2020
Use the Info Kernel and create a Z-Depth AOV from Render Settings > Octane Renderer > Render AOV group > Render AOVs turndown. Click on the Add render AOV button and choose Info > Z-Depth AOV from the menu that appears. Make sure you click on the Enable button.
omardex
Hello,
select your kernel node and change it to infochannels
bellow is a drop down where you can select the zdepth pass and under that is the maximum zdepth setting where you can configure its coverage
EDIT: Apologies I answered like I was using standalone, in c4d open your octane settings, in the kernels tab change your kernel to infochannels, in the type dropdown select zdepth, and bellow that is zdepth max to config the coverage, this renders only the zdepth and ignores everything else, no need to create AOV
if you change your kernel back it will keep your settings. e.g change it back to path tracing, but the common settings are not shared, if you changed your samples or ray epsylon it will not be the same
Omar Tavera
Awesome Generalist
omardex.artstation.com
Octane render for c4d but moving more toward standalone with one 980ti
elsksa
omardex wrote: EDIT: Apologies I answered like I was using standalone
Reassuring. I'm not the only one.
omardex
hahaha, standalone is the next step when ones start using the plugins, more stable and focused, removes the dcc system load and intervention from the equation.
Omar Tavera
Awesome Generalist
