OTOY® is proud to announce the availability of the new DCC plugin OctaneRender for Solaris V2021.1 - for Houdini 19.0.455.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrate completely with Houdini 18.5 Solaris.
The OctaneRender for Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launching it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
New features
To learn more about the new features and improvements of OctaneRender 2021.1, please check out the 2021.1 release post
- Changes since 2021.1.1 - 01 06 22 [Test]-
- Quick fix licensing issue
-Known Issues-
- Global texture AOV is in WIP
- Octane Color response is disabled because Hydra buffer expects linear output
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
However, the usual Octane light linking works as expected.
Enterprise Subscription Downloads
2021.1.1 Houdini 19.0.455
Studio Subscription Downloads
Demo build Download
Happy GPU Rendering !!
Your team
OTOY
