Hi John,
You are absolutely right, I completely missed those. I always check through the customer download section (https://render.otoy.com/account/download_archive.php) and saw the .1.1 version only for the C4D plugin, so I thought it wasn't uploaded yet.
OctaneRender™ 2021.1.1
- PolderAnimation
- Contact:
It sometimes happens that you move files. So when you open octane it says that the file is missing and you can relink the file.
But if you immediately close the file after relinking it does not ask you if you would like to save the file, but closes it without saving. So when you reopen the file again, it again says the files are missing.
Could you make it that Octane give the save prompt when closing a file where you have relinked stuff?
Thanks.
Thanks.
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
Thanks for the reportPolderAnimation wrote:It sometimes happens that you move files. So when you open octane it says that the file is missing and you can relink the file.
Thanks.
For me this version doesn't log out properly so the license is still in use after I've closed octane and after shutting down my computer in the office.
I have to unlock it when I'm at home.
Had this before in octane 2019 but in the later versions it was gone - now it's back.
MSI MPG Infinite X2 MSI GeForce RTX 4090 24 GB VENTUS Intel i9 14900KF
Nihil sum sine sole.
Hi MyRho,MyRho wrote:For me this version doesn't log out properly so the license is still in use after I've closed octane and after shutting down my computer in the office.
Are older versions still releasing your license when you use them at the office?
Yes, all the other versions (older ones) wouldn't do that.
The license was released properly.
But maybe it's something between the octane and the firewall/av here in the office. (Panda)
