Octane render experiments
And the overcast version. Tried out the nested dielectrics, overall pretty satisfied!
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
Tempted to try out the BRDF energy conserving GGX model for the water. With PMC caustics look super sharp without fog. The split-focus diopter makes for crashes along with the equirectangular camera, but going to try that out as well, along with the internal forced tonemapping. Not happy with the composition and water yet.
Around 8 hours rendering on PMC, waterplane is a mesh deformed along with a normal map + rayswitch to speed up rendertimes. Lit by octane sun + visible BG with rayswitch as well. PS for post pro.
Denoiser + adaptive sampling aren`t working with PMC on 2021.1 (yet?). So for now it`s around 50% resized from 2560 x 1080.
Version 2022 for Studio just came out, so going convert it when I can! viewtopic.php?f=33&t=78783
Yeah wow. If the Photon tracing kernel is set up correctly it`s blazing fast. The pool scene generates sharp caustics even over a procedural bump map, it`s on a 3080ti almost instantly.
Scene scale might be important I`m noticing, but wow.
For now here`s a first test! Photontracer till 1600samples, in 5 minutes on a 3080ti + 1060 max-Q. Octane 2022.1 XB0. Driver version 30.0.14.7168.
- Swimmingpool_v3.orbx
- (352 KiB) Downloaded 1163 times
Still struggling with getting that lovely noise gone (inside the flasks). 6400 samples @ 3080ti+1060 max-q takes around 15 minutes!! Can`t imagine getting this with PT/PMC.
I exported an .orbx to dive in, but it`s around 200MB for the same scene. (Okay zipped it`s 75MB!) This is lit with a sharp sun HDRI as Sky texture in Daylight environment. (Hosek)
- Beeker and Flask scene_3.rar
- (73.57 MiB) Downloaded 1280 times
Okay an interior experience with the Photon Kernel (in case I would need to render a wooden bowl that is suddenly glass) to check the workflow. For now I switched to sharp sun to generate them quicker. Diffuse lighting doesn`t generate them as sharp!
What I noticed is that the Photon Kernel and AI Denoiser don`t work together (yet!), so you need to compose PT+AI denoiser with the Photon Kernel and Render region that part, which overall adds a few minutes to the workflow. Overall 0 crashes, so it`s pretty stable.
For example the caustics generated by the bowl took about 6 minutes with render region to converge. So yeah. I think it`s a super-addition for prodviz & art, but has less use-cases for wider interiors for now. But let`s wait for the denoiser to work as well
Next up some crisp caustics. I remember on PMC it took about 8 hours to render 1 frame. After some testing/optimizing the Photon kernel actually reduced that to around 11 seconds per frame
Still pretty low res, can`t wait for RNDR to upgrade to 2022.
Another one with a different watersurface, really digging the photon kernel
In between gigs, trying out a more custom studio light setup with a different take on leather.
Trying out another take on the Photon kernel built from scratch. A few softbox lights, no IES, HDRI, ACES, some post in PS. Rendertime about 15 minutes, took a few minutes to render region out the caustics. The PT + AI denoiser takes about 2 minutes, though subtle details in f.e. fabrics are less visible + less caustics.
*Added 4 more versions higher-res, rendered overnight, 4 hours on a 3080ti.
