OctaneRender® for 3ds max® v2021.1 - 12.07
samsue
neonZorglub wrote:
samsue wrote:this "problem" with RC very annoying... I have to keep switching between direct and standard
Hi samsue,
I'll have a look at the RC issue.
Could you send a small sample with different result between Direct and Standard modes?
idk maybe i am doing something wrong.
i have used this RC Objet for over 2 years but just now start this "problem"
neonZorglub
samsue wrote:
Hi samsue,
Hi samsue,
Thanks for the video.
I could reproduce a similar issue, but without a sample scene (max file), I can't be sure it's the same..
In my case, if I change the Pivot (in the Hierarchy panel) of the RailClone object, the Direct mode do not match the correct position.
As a work around, you could try to reset the pivot to the object center
This should be fixed in the next release.
coilbook
octane renders itoo proxy as actual proxy and not as a mesh
paride4331
coilbook wrote:octane renders itoo proxy as actual proxy and not as a mesh
Hi coilbook,
I'm not sure but I think Itoo manage meshes, not objects, so it gets the simple mesh from the octprx.
But only developers can fully answer this issue.
Regards.
neonZorglub
Hi coilbook,
Regards.
Hi coilbook,
It seems to work for me: (FP Pro 7.1.1)
FFP-simpleTest06_FpProxy.zip
(110.86 KiB) Downloaded 164 times
That's just setting Forest pack display mode to proxy.
But there was another problem, when trying to use Octane proxy objects (octprx files) as geometry for FP, FP gets the simplified mesh instead of the full mesh. but that doesn't seems to be like in your screenshot ..
This has been fixed, and you can you both octane proxy and FP proxy mode:
FFP-simpleTest09_OctProxy_and_FpProxy_OK.zip
(226.01 KiB) Downloaded 157 times
Could you share a sample scene ?
HHbomb
I wonder if the "Nested dialectrics" setting in Kernel type is working at the opposite : if unchecked, nested dialectrics works.
paride4331
HHbomb wrote:Hi,
Hi HHbomb,
If disabled, the surface IORr not tracked and surface properties are ignored.
Don't forget to set the material priority.
HHbomb
I mean, I think the checkbox is inverted
paride4331
HHbomb wrote:I mean, I think the checkbox is inverted
Hi HHbomb,
try by changing material priorities.
test.zip
(2.56 MiB) Downloaded 156 times
mbetke
I noticed the opacity of my flame gets killed as soon as I move it behind the large glass (specular material).
PURE3D Visualisierungen
Return to “Releases”
