My first post
I'm here with good reason - after much hunting around I've worked out that for obvious reasons, this forum is probably the best location (in the world!) to track down users who are using a GTX 4XX card to run their primary display in 3dsmax (or maya, but I'm primarily interested in 3dsmax being a max user). It's a bit of a niche use for a card that is primarily for gaming, at the end of the day.
I'm trying to work out the components for a new build desktop at the moment, and am keen to get a GTX, probably 470, with a view to later getting into octane. I'll probably get two 470's in an SLI, just for game purposes so will have a fair bit invested in this card. However I can't help being extremely concerned about the apparent number of users having problems running 3d apps and the GTX 4XX cards. If you google '3dsmax gtx 480' you will find countless threads of cases where users 3dsmax and maya viewport speeds are experienced at say < 10 fps, and a whole lot of outraged customers...There's even a section on wikipedia! The worrying thing was that a lot of these threads don't end with any solution being found, and just trail off. However a lot of the threads are also from earlier this year.
This thread on the Octane forum, in the third post from Andrian, is the only report I have had of a user not experiencing any problems in the 3dsmax viewport, which is extremely reassuring:
http://www.octanerender.com/forum/viewt ... 7&start=40
Andrian appears to be a pretty active user here and seems to still be doing just fine with a gtx 480. However he mentions using the 197.75 WHQL version of the drivers, dated from May 2010, even at a time when these were superseded (now up to 263.09). Other reports I found suggested that using the right version driver did make the difference between viewport speed being really fast, and completely unacceptable (nothing in between).
So to reassure myself that this card is for me, would greatly appreciate your thoughts on the following:
1. Do you use a GTX 4XX card as a primary display (for modelling/editing), with max or maya?
2. Have you had any problems with frame rate?
3. What version driver are you currently using? - this is the most critical issue. If there is only one driver version that lets this card run acceptably in 3dsmax/maya and everyone is still clinging to that driver, then this does not seem to bode well for the future. It would be great to know that in general, the cards still work ok with more recent drivers.
4. What 3d apps have you successfully used with the GTX 4xx? I am using 3dsmax 2011, whereas Andrian's success appeared to be with 3dsmax 2009. A number of the problems seem to be reported on 3dsmax 2011. It's one more factor for me to be worried about...
Thanks in advance for anything that will shed light on the current status of this problem.
