OctaneRender 2021 for Modo [OBSOLETE]
Hesekiel2517
Maybe you can help me with another problem. I have a scene with motion blur and I noticed that sometimes the export results in a Blur Length of 20% and sometimes 50% (as it was set in Modo). Is there also something i could have done wrong?
funk
You'll need to get a scene to Paul so he can check it out.
GOTHACOM
Does Render animation work with new 177 build? Mine saves the first file only, then renders but doesn't save all other frames.
It works (same scene, same settings) rolling back to build 176.
Attached is a screenshot of my render setting.
G
yoshikai
I have the same issue.
It happened when I saved a scene as exr32 multi-layer.
The strange thing is that this doesn't happen in all scenes, but when I tried it in a simple scene, the sequential numbers were output as usual.
I don't know what is causing this.
Also, there are scenes where motion blur is not applied.
In a simple scene with a moving teapot, motion blur was not applied in the preview, but when it was rendered out, motion blur was applied.
In the attached scene, motion blur was not applied when it was output.
When I loaded it into octane (standalone) to test it, motion blur was applied.
I've uploaded a simple scene file.
could you check my scene?
https://yoshikai3d.tenpu.me/download/1j ... 9reoehb8j7
yoshikai
Here is a video of the save issue.
Only the first frame is saved.
https://yoshikai3d.tenpu.me/download/yc ... z52bpqja75
GOTHACOM wrote:Does Render animation work with new 177 build? Mine saves the first file only, then renders but doesn't save all other frames.
G
I will release a new version which fixes this issue in the next 12 hours.
GOTHACOM
G
Thank you very much Paul!
G
I have updated the installers at the top of this thread with:
2021.1.0.178
- Fixed issue introduced in 2021.1.0.177 where multi-layer EXR files were not saving correctly when rendering animations
yoshikai
Thank you so much!
2021.1.0.179
- Compiled with Octane 2021.1
- Fixed issue where Film Offset was not being exported to ORBX files
- Fixed missing Enable Barn Doors property on the Volumetric Spotlight
- Added "Surface Brightness" and "Keep Instance Power" to Octane Lights
- Added support for plugging an Octane String node into the "name" channel of the Octane Vertex Attribute texture nodes
- EXPERIMENTAL: You can now attach an Octane Node Graph to the Geometry pin of a Mesh, and add/edit Octane Geometry nodes in the Node Graph editor
Return to “Foundry Modo”
