WOW! You could handle the AVX2 options issue! This version seems to run as desired.aoktar wrote:I've updated to RC3 with some fixes. Enjoy it!
Thank you very much!
Ron
I hope this can return as an easier way to add in the output settings. The AOV manager is great, but it was nice being able to easily toggle denoised beauty pass without needing to add a bunch of nodes.BCres wrote:You can get a denoised beauty with this setting (see pic). Some others on the forum helped me figure this out. Hope it helps.
Can't be sure what's topic about that but did you try this new parameter? It will activate a denoised beauty pass(AOV). I had to add this as different way because there's not a denoised beauty AOV in core. It's an exception.ndreimi wrote:I hope this can return as an easier way to add in the output settings. The AOV manager is great, but it was nice being able to easily toggle denoised beauty pass without needing to add a bunch of nodes.BCres wrote:You can get a denoised beauty with this setting (see pic). Some others on the forum helped me figure this out. Hope it helps.
aoktar wrote:Can't be sure what's topic about that but did you try this new parameter? It will activate a denoised beauty pass(AOV). I had to add this as different way because there's not a denoised beauty AOV in core. It's an exception.ndreimi wrote:I hope this can return as an easier way to add in the output settings. The AOV manager is great, but it was nice being able to easily toggle denoised beauty pass without needing to add a bunch of nodes.BCres wrote:You can get a denoised beauty with this setting (see pic). Some others on the forum helped me figure this out. Hope it helps.
You may kindly send a scene which causes this with detailed info. Because it's not crashing herewrapthereal66 wrote:again, background object make octane crash ! i don't know how i can help you with that ! but when i have a background with image sequence in it and when i start a live render, BOOM crash ! :/ really annoying
