Cinema4D version 2021.1-RC2(R3) (Current 2021) 04.10.2021
rifat
rifat wrote:
aoktar wrote:
rifat wrote:Hi really loving the new ACES side of the octane!
I just had 2 small issues with D65 and saving directly out from PV as png.
1)
when it's directly saved as PNG.
the white balance doesn't match with D65, but it matches with legacy/flat
( seem like it's missing a D65 transform when save from PV to PNG)
When save as directly out as EXR, every colour looks right as I set it as ACEScg.
2)
I have denoiser turned on.
but non of my multipass exr pass has Denoise applied, at least the beauty pass isn't. Would be great to find a solution for this first.
Cheers
Rif
Not sure what you mean to first, if you're saving as PNG/EXR in LV then plugin will use Octane's saving functions. I cannot see any problem on saving. Maybe worth to illustrate it a bit better.
About second, you cannot get denoised results in to beauty if you're using Octane-EXR. Because it's directly saved from Octane render buffers. With other formats we can do that because there's a transfer buffer(copy denoised to beauty) to revise.
Awesome Wehn and where we should use octane-EXR?
1)
The attachment octane colour.jpg is no longer available
BTW I tested to render png not octane exr as you said. denoiser did not work
rifat wrote: BTW I tested to render png not octane exr as you said. denoiser did not work
Not sure why you cannot solve it, but it will save denoised beauty if you save main buffer with "use denoised beauty pass" option and denoiser activated.
ndreimi
Apologies if this has been discussed already. When using Spot lights, with no medium enabled, there are artifacts where the outer edge of the cone interacts with geometry in the scene.
miohn
jayroth2020 wrote:Mike, can you post a simple scene file? Let's take a look at your setup.
Hi Jayroth,
did you already have the opportunity to look at my testfile?
Still cannot get the BG to show up in the Multipass PSD.
Can you tell me if I forgot to enable something or is it a software problem?
Btw. is there an detailed tutorial about the new AOV System in 2021?
thanks
Mike
jayroth2020
Hi Mike, I have been looking at your file, and I have a question into the devs about it. I do not see a way to specify the BG in 2021 as an AOV output. I am reminded that 2021 is still under active development and not yet complete (production use is not yet recommended), and that is likely the reason. That is also why tutorials have yet to appear — they will once the feature is complete.
miohn
jayroth2020 wrote:Hi Mike, I have been looking at your file, and I have a question into the devs about it. I do not see a way to specify the BG in 2021 as an AOV output. I am reminded that 2021 is still under active development and not yet complete (production use is not yet recommended), and that is likely the reason. That is also why tutorials have yet to appear — they will once the feature is complete.
Hi Jayroth,
good to know! Thanks much that you have dealt with it.
I know that 2021 is not yet production ready, so I wanted to ask
if thats not implemented yet or I may have overlooked something.
regards
Mike
Hi Jayroth,
regards
Mike
Background objects will not be supported AOV system or render passes. You can just use with main render buffer. You have to find another way for mixing images with AOVs in AOV system
marcus1070
Denoised Beauty are not being outputed on the render passes.. Denoiser active, save beauty.. you can see the denoised result on the picture viewer, but the file on photoshop is the standart beauty
CFG:
PS:
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Nvidia driver version: 516.94
- Cinema 4d r25
- Plugin version Studio+ 2022.1(r7)
http://www.marcusrizzo.com
Ron
This version is crashing R25 as soon as I open Octane settings or Live Viewer ...
Any one else having this issue?
What could be the reason?
Regards - Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
miohn
marcus1070 wrote:Denoised Beauty are not being outputed on the render passes.. Denoiser active, save beauty.. you can see the denoised result on the picture viewer, but the file on photoshop is the standart beauty
CFG:
PS:
the Light-Pass "Sun" not outputted as well!
regards
Mike
Return to “Releases”
