OctaneRender 2021 for Modo [OBSOLETE]
DERJUNG
Hi guys,
Is there a time frame when Octane X will work on Modo 15? It seems that the development for Modo is far behind (PR8 vs PR11c4d). Are too few people using it, or why can't I use it? It's a bit of a hassle to always use Cinema 4D as a render program when I create everything else in Modo 15.1. Can we still expect it or has it been abandoned and it is already somewhere here in the forum? I just need a clear announcement. Then I switch to blender, which seems to be the most future-proof.
MacPro 12 [email protected] Ghz - 48GB 2933Mhz DDR4 - AMD Radeon Pro Vega II Duo 32GB
Hi - I have issues with PR11 crashing Modo, so unfortunately it will require OTOY investigates - which they will action at some point. Sorry for the delay.
JoGo23
Hi Paul - Is it possible to play with an instable version or is it really unusable?
It crashes when Modo is starting, so it's not much use.
I have updated the installers at the top of this thread with:
2021.1.0.176
- Compiled with Octane 2021.1 RC2
Hesekiel2517
Hey Paul,
an OSL Texture I often use causes an errormessage (but does work):
FileName::existsAsFile() can be called only on absolute file names
It's the code at the bottom of this page:
viewtopic.php?f=30&t=68094
Is this an modo or octane issue?
funk
Hesekiel2517 wrote:Hey Paul,
The error is actually in the script, but previous Octane versions were just silently ignoring it, and this causes some issues with the way the plugin builds the nodegraph.
You can fix the script by changing
string File = "1",
to
string File = "",
Hesekiel2517
Thank you very much!!
neverko
Hi good Modo/Octane people,
I upgraded my old OctaneRender 4 license to 2020.x last night and so far, so good. I'm up and running in Modo 15 on my RTX 3070 Ti.
I have a question that's not directly tied to the Modo plug-in, but I'll just ask it here. It's about general licensing.
I know that when you currently buy a new license with 12 months maintenance you pick a fallback plug-in to keep if/when maintenance lapses. But I don't think there was anything like that when I upgraded my V4 license to 2020.x perpetual with 12 months maintenance.
Under my licenses OctaneRender standalone says 2020 and "Status" is "All access".
The Modo plug-in license below still says Version 4. (I don't have any other old V4 plug-ins).
So how does this all work if/when my current maintenance lapses in the future. Is Modo for 2020.x my fallback plug-in since I don't have any other plug-ins?
It's just currently a bit unclear as the license still says Version 4.
Thank you!
Ryzen 9 5900X, 32GB RAM, RTX 4070 Ti Super, Windows 10 x64
neverko wrote:Hi good Modo/Octane people,
Thank you!
As this is not directly related to the plugin functionality, I suggest submitting a ticket to OTOY via the Support menu option at the top of this thread.
Return to “Foundry Modo”
