volume spot light in 3dsMax
patis
Hello, I am Octane for 3dsMax User.
I don't know how to adjust power of Volume spotlight.
It is always max....
paride4331
Hi Patis,
you would use some octane nodes to adjust the Octane spotlight,
spot3.rar
(67.76 KiB) Downloaded 233 times
coilbook
paride4331 wrote:Hi Patis,
Hi Paride,
How do I change light color? How do you adjust spot brightness? When I add diffuse with emission to emitter material my small spot light disappears and the whole floor has light . Thanks
coilbook
Also when I set volume to red light becomes opposite color
paride4331
Hi coilbook,
I hope it helps.
vollight.zip
(84.6 KiB) Downloaded 158 times
coilbook
paride4331 wrote:Hi coilbook,
I hope it helps.
Thanks. Do you know if octane uses real volume lights or it's some fake 3d cone with scattering material? Why do CPU renders have a vast varieties of volumetric lights and GPU are so weak at it? Thanks
paride4331
I hope it helps.
Hi coilbook,
it's a 3d cone with scattering material; alternatively you could use a "classic" fog cube.
viewtopic.php?f=27&t=59549&p=304625&hilit=fog#p304633
New coming Octane features should also help in this way.
https://youtu.be/AkoAm7zWgVI?t=1084
