Hi, is it possible to see denoising process in the viewport in real time?
Enable Denoising is ON
Denoise on Completion is OFF
It shows sample count as 100/200/1000, indicating that 100 samples were denoised, but I still can't see denoiser progress in the viewport, only the noisy picture.
Denoiser in a viewport?
Try changing to viewport display to the denoise render pass. This works similar to how the final render works in that you need to change the viewer to the denoise render pass to see or save it.
Jason
Jason
- linograndiotoy
You need to set the Preview Pass to Denoiser Beauty.kabakZ wrote:Hi, is it possible to see denoising process in the viewport in real time?
