Cinema4D version 2021.1 RC1-R3 (Older 2021.1) 10.08.2021
Ron
Hi Ahmet,
sorry for bothering you with such issue, but I have problems with this version:
I re-newed my subscription licence (enterprise) but the plugin is not recognized by C4D S24.
When I use V2020 it works as expected. What am I doing wrong here?
Thanks for your help!
Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
BCres
On my computer, the choices for which Crytomattes to use is missing with 2021.1 RC1 and RC3 plug.
What I used to get. Did something change?
jayroth2020
Yes, there are differences between the 2021.1 builds and the previous 2020.x builds. The 2021.1+ builds expand the AOV system significantly, and there are numerous UI changes.
BCres
Thank you, Jay. I figured I had missed something. Yeah, it's buried in there, but I'll figure it out.
A lot like Premiere's switch to the AE titling. It's taken a while to show it's fruit, but in the end I'm sure it'll be a better way of doing things.
**So where is "Denoised Beauty" in the AOV choices?
jayroth2020
To get a Denoised Beauty AOV, create a Render AOV output node, which connects to a Composite AOV output layer node, which connects to a Composite AOV Output node, that is connected to the Octane Render node. Select the Render AOV Output node, and set the Input drop-down to Pass:Denoised Beauty.
See here:
BCres
Thank you, Jay. That's a huge help. I appreciate all of your time.
**Found I get the denoised pass in my .exr if I check "save beauty" in The Octane render pass tabs and I dont check it under the main render tab.
Ron wrote:Hi Ahmet,
Ron
You need latest C4D
karl
DARIOALVA wrote:Hi. Thanks for the hard work! just noticed that in these latest releases I can't save render stills from the Live Viewer in PNG8-bit with Alpha (it only works on 16bit PNG). I'm getting black background png images (working on R23). Is this some kind of update? Tested in version 2020.2.3-R2 and it was working nicely there.
Thank you,
Thanks for the report, this was a core Octane issue and will be fixed in 2021.1 RC2.
Ron
aoktar wrote: You need latest C4D
Thanks - that solved this issue. The S24-Update hint is not easy to find :-(
Ron
useruser
Thank you ahmet! :)
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
Return to “Releases”
