Maybe I'm overlooking something.
Currently I am rendering a short test animation, each frame takes 5-6 second to render.
In between each frame being rendered Octane displays WAITING, for roughly 10 seconds. (double the time of the render!). Then it quickly updates the scene and starts rendering for 5 seconds again.
Then Waiting for 10 seconds, rinse and repeat.
What is it doing in the mean time?
The EXR is already written to disk, and I have time to open it in Photoshop before WAITING is over.
Is there something I can do to shorten the WAITING period or get rid of it at all?
Just wondering and trying to understand what it's doing.
Br,
Hans
Status: Waiting...what does it do?
Usually, this message means that the plugin is waiting for the Layout to update the scene, so it is hard to know what is happening under the hood. Perhaps the scene has subdivision surfaces, or multiple steps motion blur, etc. ... something that needs a lot of time to be updated.
Back with this, sorry
Something weird is going on.
The scene is rather large, so it makes sense it takes a while. (quite some instances)
I have disabled all update stuff, because except for moving objects and camera's nothing special happens.
A frame renders in roughly 7-8 seconds, but WAITING takes around 50 seconds now. (rendering with F10)
Updating scene is only displayed for barely one second.
When WAITING is displayed, layout shows not responding in Taskmanager.
Rendering each frame manually with f9 is a few seconds quicker somehow.
Also, somehow it WAS quick (was able to do 3 or 4 frames / minute, but suddenly it has dropped to one frame/minute (7 seconds really doing something usefull)
It must be something in this scene, but I have no idea why it was first ' quick' and now really crawls.
System is CPU = i9 -9820k, 64GB RAM, 2x 2080ti, 2x 1080ti and a bunch of NVME drives where the data is stored/written to.
Sorry, I'm not sure what could be the problem without taking a look at the scene but do you have the motion blur enabled, with multiple instances MB or something like that? Evaluate a complex scene with instances at multiple time slices to get the MB can be very slow. Try to disable the MB to see if it is the source of this issue. Also, perhaps you could enable the Octane log in the plugin options panel and attach it here to check if there is any clue on it about this issue.
Hi Juanjo,
I have a log! From the entire rendering sequence. Can I email it to you?
Motion blur is activated indeed, and, (you knew this ... you're the best) without motion blur it 's really quick!
Never knew that, this is the first scene in years I've activated motion blur
Sorry to have bothered you with this, another lesson learned!
Any setup to make it quicker?
https://youtu.be/i2z_4J9fLUg Here is a link of what was cooking (246 frames, took 3 hours to render at 7 seconds per frame
Hans
Hans
- wavesoflight
I know this is an old thread, but I ran into the same problem today. I think I have found the issue.
If you have a large number of subframes in the LW Camera settings and you have MB turned on in the Octane Render Target, the WAITING sign appears. If you set the Subframes to 1, no WAITING between frames.
Does the Subframe setting in the LW Camera make any different when rendering MB with Octane.... surely the MB steps in the Render Target are what controls it. In fact, I ran a comparison and there doesn't seem to be any different with the resulting render when I have subframe set to 1 or 20 (expect at 20 my WAITING times are 20 secs per frame!).
Regards,
Ricky.
Regards,
Ricky.
Interesting ... the subframe setting in the LW Camera is not used by Octane at all, but they can be taken into account by the Layout while processing each time sample for the plugin, so yes, it is possible that this could make the scene updating really slow on the LightWave side, even if all these computed subframe are not used by Octane at all.
