OctaneRender 2020.2 for Houdini Production build 2020.2.4.0
juanjgon
This is a production release of the OctaneRender™ 2020.2 for Houdini™ plugin compiled with the Octane 2020.2.4 core. This 2020.2.4.0 release is available for the latest Houdini production builds on Windows x64, Linux gcc6.3.1 and MacOS 10.12 (CUDA).
Houdini production builds supported by this release: 17.0.506, 17.5.460, 18.0.597, 18.5.532, 18.5.563, 18.5.596 and 18.5.633
Make sure to use an NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux to use this version. No driver updates are required for macOS 10.13 (CUDA).
New features
To learn more about the new features and improvements of OctaneRender 2020.2, please check out the 2020.2 release post, but this is a brief list of the main new features that have been added.
  • Improved RTX performance.
  • Fast Spectral Nested Dielectrics.
  • Denoiser support for the new NVIDIA Ampere devices.
  • ACEScg and filmic processing. New color options available in the Octane ROP node.
  • OpenColorIO Management, Display and Export (OCIO profile). Configured from the "OCIO" environment variable.
  • OpenColorIOColor graph nodes. Look, Profile and View nodes
  • Integrated multi-scatter from volumes or surfaces. Available in the Octane OBJ spare parameters.
  • User generated compositor AOV passes for combining render and light passes in full a compositor node graph.
  • Null material.
  • Spotlight texture.
  • New ray type, texture composite and channel tools shader nodes.
  • Improved color correction node.
  • New chaos texture node.
Release 2020.2.4.0 Enterprise subscription license
https://render.otoy.com/customerdownloa ... rprise.zip
Release 2020.2.4.0 Studio subscription license
https://render.otoy.com/customerdownloa ... studio.zip
Release 2020.2.4.0 Demo license
https://render.otoy.com/plugindownloads ... 4_demo.zip
https://render.otoy.com/plugindownloads ... x_demo.zip
https://render.otoy.com/plugindownloads ... X_demo.zip
Release 2020.2.4.0 for Houdini 18.5.633 All licenses and OS
https://render.otoy.com/plugindownloads ... 3_demo.zip
Standalone 2020.2.4 version for the network rendering nodes
viewtopic.php?f=15&t=77888
Release Notes
RELEASE 2020.2.4.0
* PLUGIN FEATURES AND FIXES:
- Added H18.5.596 plugin build.
- Fixed a problem with the space characters in the paths included in the plugin options panel.
* OCTANE FEATURES AND BUGS FIXED:
- Fixed render failure when using a stereo panoramic camera with a focal depth set to zero with RTX on.
- Fixed render issue with microfacet models not calculating reflectance on total internal reflection.
- Fixed rendering regression with hair rendering in 2020.2 builds compared to 2020.1.5.
- Fixed shadow catcher material not responding to the opacity pin value.
- Fixed image texture transform conversions loading very old materials.
- Fixed case in which OSL textures would not be compiled upon being created or loaded.
- Fixed memory leak when using the baking texture node.
- Fixed incorrect texture mapping when the Z component of a UV transform is zero.
- Fixed issue causing UV transforms being ignored with plane primitives.
- Fixed flickering and brightens with the Hosek-Wilkie daylight model when using small sun sizes.
- Fixed possible application crash when using SDF/Vectron shaders which expose multiple materials.
- Fixed volume contribution for Cryptomatte passes which were counted twice.
- Fixed motion vector pass for triangles with deformation.
- Fixed issue with the denoiser causing an output color difference from the original pass.
- Fixed color blend and alpha operation combinations using output AOVs.
- Fixed differences between composite AOVs and the beauty pass.
- Fixed some unnecesary render restarts.
- Fixed issue causing ORBX packages to miss some data when being overwritten.
- Made renaming from temporary ORBX package file name more robust.
- Fixed the AI denoiser and upsampler for macOS.
- Fixed upsampling when the alpha channel is enabled.
- Fixed performance issue when resizing the LocalDB panel
Happy rendering,
Your OTOY Team
Sportler
Thanks so much. Would be great to see a version for v633 too!
GPU: 1x Nvidia RTX 3080 Ti
RAM: 64GB DDR4 3200MHz
CPU: 5950x
juanjgon
Sportler wrote:Thanks so much. Would be great to see a version for v633 too!
As usual, I'm waiting to check if there is a new Octane 2020.2.5.0 core before releasing a new build, but if it is not available soon, I'll include in this post a plugin build for this Houdini version using the current core.
Sportler
Awesome, thanks!
CPU: 5950x
juanjgon
I've updated this post including a new plugin build for H18.5.633
Sacha.wech
Hello,
I get an error when I try to run the studio plugin version for 18.5.633
Am I doing something wrong perhaps?
Cheers
Sacha
Error message
Error message
juanjgon
Sacha.wech wrote:Hello,
Cheers
Sacha
Do you have the right path to the plugin/bin directory in the houdini.env file PATH variable?
Return to “Releases”
