Octane Unreal Plugin with MetaHumans
Moderator: ChrisHekman
- ChrisHekman
I just got my early access, will check it out.
- andy_shindin
Hey Chris, did you find a solution for MetaHumans?)
- EvolverInteractive
If you read the user agreements and even the small prompt that pops up before you start it says that metahumans can only be rendered with unreal. Specifically saying that. I would assume they would need permission before they would spend the resources to do integration.
- Jolbertoquini
- Contact:
I hope this will be a posibility , presumabuly will be soon
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
- ChrisHekman
I found two possible solutions. Metahumans is high on the feature list.
But first im doing UE5 and UE4.27.
- Jolbertoquini
- Contact:
Great news!!! nicee!! Thanks Chris!ChrisHekman wrote:I found two possible solutions. Metahumans is high on the feature list.
- Respecognize
Actually also curious if the most recent octane and ue 5.1 works with metahumans? If not I might have to use a different character creator.
- ChrisHekman
Metahuman support is close to fully supported - however there are a few small issues that might break some of the materials or hair materials.Respecognize wrote:Actually also curious if the most recent octane and ue 5.1 works with metahumans? If not I might have to use a different character creator.
We are working on these, but in many situations metahumans should work for you.
