OctaneRender 2020 for Modo [OBSOLETE]
Forums: OctaneRender 2020 for Modo [OBSOLETE]
Re: OctaneRender 2020 for Modo [TEST and STABLE]
Postby evan.musin » Mon Jun 14, 2021 4:58 pm
evan.musin Mon Jun 14, 2021 4:58 pm
Modo 15 won't start anymore, if the Plugin (V171) is active. I already deleted config files, and reinstalled the plugin. Is there a quick fix to this?
We had this same issue at our studio - opened up MODO 15 this morning and couldn't get past the splash screen due to an octane pop-up not responding. We ended up installing the latest Octane Standalone (2020.2.4), uninstalled all Octane MODO plugins, then reinstalled the stable 171 version and that seems to have worked.
Hi - these appear to be general Octane questions. May I suggest posting them in the Octane Standalone 2020.2.3 release thread, and include an ORBX which illustrates the issues, and the OTOY support techs can then response.
Thanks Paul,
These issues are specifically pertaining to the MODO version of Octane. They have been tested in other plugins and seem to work fine. There is an issue in MODO Octane with vertex maps working used as an amount for a Mix Material with "nested dielectrics" checked on, happens every time. It only selects one of the colors being mixed and goes with it, ignoring the other mix. There is also an issue with displacement not working correctly in MODO. I cannot get the mid-level to remain static, it always seems to move a little, which really kills any thin meshes, such as glass bottles. I have used the exact same displacement maps in Cinema4D Octane and it works just fine. Let me know if you need any examples and I can create a few - can't show exactly what I've got due to client restrictions.
Sorry for pretty much posting the same thing twice, but these couple issues are limiting our options quite a bit for a couple of our clients. Thank you!
evan.musin
Postby Hesekiel2517 » Tue Jun 15, 2021 8:23 am
Hesekiel2517 Tue Jun 15, 2021 8:23 am
Hey Evan,
thank you very much. That worked!
Hesekiel2517
Postby face_off » Wed Jun 23, 2021 12:39 am
face_off Wed Jun 23, 2021 12:39 am
I have updated the installers at the top of this thread with:
2020.2.4.173
- Built with Octane 2020.2.4
- Fixed issue where the plugin would freeze Modo15 on startup
Postby funk » Wed Jun 23, 2021 12:56 am
funk Wed Jun 23, 2021 12:56 am
Thanks Paul
Win10 Pro/ Ryzen 5950X / 128GB / RTX 4090 / MODO
funk
Postby Hesekiel2517 » Wed Jun 23, 2021 8:28 pm
Hesekiel2517 Wed Jun 23, 2021 8:28 pm
Thank you Paul!
I found two issues: Changing from single layer exr to multilayer exr triggers a restart of the render.
Also my beloved command octane.renderandsave does not work anymore. If i add a filepath modo crashes. This is a major issue for me, because my batch render script relies on this command. A quick fix would be great!
Hesekiel2517
Postby funk » Wed Jun 23, 2021 8:51 pm
funk Wed Jun 23, 2021 8:51 pm
Hesekiel2517 wrote:Changing from single layer exr to multilayer exr triggers a restart of the render.
Can you post some steps? I tried the following and its not restarting here
1. Create new scene with the cube and started rendering.
2. Click save image, save format = EXR 32 bit, and change layers from single to multi-layer
funk
Postby Hesekiel2517 » Wed Jun 23, 2021 9:09 pm
Hesekiel2517 Wed Jun 23, 2021 9:09 pm
Mhmm strange, i don't get the same behavior on a new scene.
Hesekiel2517
Postby Hesekiel2517 » Wed Jun 23, 2021 9:11 pm
Hesekiel2517 Wed Jun 23, 2021 9:11 pm
Render and Save Command is also not working in Modo 14.2. So it's no V15 thing
Hesekiel2517
Postby face_off » Thu Jun 24, 2021 12:13 am
face_off Thu Jun 24, 2021 12:13 am
Hesekiel2517 wrote:Render and Save Command is also not working in Modo 14.2. So it's no V15 thing
The octane.renderAndSave command was modified for Octane 2020.2 (plugin version 2020.2.0.165 from the 10-Feb-2021) and did not work correctly from there onward. The last version it worked was 2020.1.5.163 (from 18-Sep-2020). I can take a look at fixing it, however I would prefer to put through the fix in the Octane 2021.1 stream of the plugin.
Postby Hesekiel2517 » Thu Jun 24, 2021 1:14 pm
Hesekiel2517 Thu Jun 24, 2021 1:14 pm
Hi Paul,
thank you for answering so quickly! For this project i worked around by saving out Orbx files and then batch render them in Standalone. However there is a project coming up in the next 2-3 Week where this Workflow would probably don't work. It would be cool if you take a look at it. Otherwise i have to go back to 163.
Thank you in advance!
Hesekiel2517
PreviousNext
Return to Foundry Modo
Tue Jun 04, 2024 3:54 am [ UTC ]
