Hello everyone,
I wanted to create a material via Python but I've been struggling to add a Displacement node. I can't find its ID. On the Internet I could find some of them but I could not find full list.
Is there anyone who knows Displacement Node ID?
ID_OCTANE_COLORCORRECTION = 1029512
ID_OCTANE_INVERT_TEXTURE = 1029514
ID_OCTANE_MULTIPLY_TEXTURE = 1029516
ID_OCTANE_MIXTEXTURE = 1029505
thank you
How to find all Octane Node IDs to use with Python?
find c4d_symbols.h under c4doctane and search the IDs
thank you.aoktar wrote:find c4d_symbols.h under c4doctane and search the IDs
#define _C4D_SYMBOLS_H
#define ID_OCTANE_LIVEPLUGIN 1029499
#define ID_OCTANE_MESSAGEPLUGIN 1029500
#define ID_OCTANE_DIFFUSE_MATERIAL 1029501
#define ID_OCTANE_MIX_MATERIAL 1029622
#define ID_OCTANE_PORTAL_MATERIAL 1029623
#define ID_OCTANE_HAIR_MATERIAL 1054119
#define ID_OCTANE_VIDEOPOST_RENDERER 1029525
#define ID_OCTANE_OBJECTTAG 1029603
#define ID_OCTANE_FALLOFFMAP 1029503
#define ID_VOLUMEOBJECT 1035792
#define ID_SCATTER_OBJECT 1035961
#define ID_SIMPLEMAT 1401164
#define AO_EMITTER_OBJECT 1041085
#define ID_VECTRON_OBJECT 1050417
#define ID_ORBX_LOADER 1050418
/// octane colour textures
#define ID_OCTANE_RGBSPECTRUM 1029504
#define ID_OCTANE_GAUSSIANSPECTRUM 1029507
#define ID_OCTANE_FLOAT_TEXTURE 1029506
#define ID_OCTANE_CAMERATAG 1029524
#define ID_OCTANE_LIGHT_TAG 1029526
/// image textures
#define ID_OCTANE_IMAGE_TEXTURE 1029508
//#define ID_OCTANE_ALPHAIMAGE_TEXTURE 1029509
//#define ID_OCTANE_FLOATIMAGE_TEXTURE 1029510
/// octane mapping textures
#define ID_OCTANE_MIXTEXTURE 1029505
#define ID_OCTANE_CLAMP_TEXTURE 1029511
#define ID_OCTANE_COLORCORRECTION 1029512
#define ID_OCTANE_GRADIENT_TEXTURE 1029513
#define ID_OCTANE_INVERT_TEXTURE 1029514
#define ID_OCTANE_COSINEMIX_TEXTURE 1029515
#define ID_OCTANE_MULTIPLY_TEXTURE 1029516
#define ID_OCTANE_ADD_TEXTURE 1038877
#define ID_OCTANE_SUBTRACT_TEXTURE 1038878
#define ID_OCTANE_COMPARE_TEXTURE 1038879
#define ID_OCTANE_MATH_TEXTURE 1038880
//#define ID_OCTANE_OSL_TEXTURE 1038881
#define ID_INSTANCE_RANGE_TEXTURE 1039376
#define ID_INSTANCE_COLOR_TEXTURE 1039377
#define ID_OCTANE_OSL_TEXTURE 1039813
#define ID_OCTANE_TOONRAMP_TEXTURE 1040143
#define ID_OCTANE_NODEGRAPH_TEXTURE 1038623
#define ID_OCTANE_IMAGE_TILES 1051204
#define ID_OCTANE_VOLUME_RAMP 1036942
/// octane generator textures
#define ID_OCTANE_CHECKSMIX_TEXTURE 1029517
#define ID_OCTANE_RIDGEDFRACTAL_TEXTURE 1029518
#define ID_OCTANE_SAWWAVE_TEXTURE 1029519
#define ID_OCTANE_SINEWAVE_TEXTURE 1029520
#define ID_OCTANE_TRIANGLEWAVE_TEXTURE 1029521
#define ID_OCTANE_TURBULENCE_TEXTURE 1029522
#define ID_OCTANE_MARBLE_TEXTURE 1029523
#define ID_OCTANE_NOISE_TEXTURE 1033698
#define ID_OCTANE_BAKING_TEXTURE 1039681
#define ID_OCTANE_TRANSFORM 1030961
#define ID_OCTANE_UVW_TRANSFORM 1039678
#define ID_OCTANE_TEXTURE_PROJECTION 1031460
#define ID_REFERANCE_SHADER 1031605
#define OCTANE_CUSTOMGUI 1029527
#define OCTANE_COLORGUI 1029945
#define OCTANE_FLOATSLIDER 1030680
#define ID_OCTANE_SCATTERING_MEDIUM 1029509
#define ID_OCTANE_ABSORPTION_MEDIUM 1029510
#define ID_OCTANE_VOLUME_MEDIUM 1036940
#define ID_OCTANE_RANDOMWALK_MEDIUM 1054109
#define ID_OCTANE_NULL_EMISSION 1029640
#define ID_OCTANE_BLACKBODY_EMISSION 1029641
#define ID_OCTANE_TEXTURE_EMISSION 1029642
#define ID_OCTANE_ENVIRONMENT_TAG 1029643
#define ID_OCTANE_DAYLIGHT_TAG 1029754
#define ID_OCTANE_MATERIAL_CONVERT 1029770
#define ID_OCTANE_DIRT_TEXTURE 1029975
#define ID_OCTANE_SCENEHOOK 1030798
#define OCTANE_FLOAT3SLIDER 1030909
#define OCTANE_CUSTOMDATATYPE 1035643
#define ID_OPEN_OCTANE_DIALOG 1031193
#define ID_OCTANE_TEST 1031194
#define ID_OCTANE_OPEN_SETTINGS 1031195
#define ID_OCTANE_LIVE_VIEWER 1031198
#define ID_OCTANE_BROWSER 1031267
#define ID_OCTANE_DISPLACEMENT 1031901
#define ID_OCTANE_RANDOMCOLOR 1032069
#define ID_OCTANE_POLYGONSIDE 1034143
#define ID_OCTANE_HELPDIALOG 1033750
#define ID_OCTANE_TEXTURE_DIALOG 1035275
#define ID_OCTANE_WCOORDINATE 1038090
#define ID_OCTANE_TRIPLANAR 1038882
#define ID_OCTANE_MATERIAL_LAYER 1052932
#define ID_OCTANE_DISPLACEMENT_MIXER 1053031
#define ID_OCTANE_AOV_NODE 1056125
#define ID_CREATE_DAYLIGHT_PLUGIN 1033863
#define ID_CREATE_PLANETARY_PLUGIN 1050513
#define ID_CREATE_AREALIGHT_PLUGIN 1033864
#define ID_CREATE_CAMERA_PLUGIN 1033865
#define ID_CREATE_ENV_PLUGIN 1033866
#define ID_CREATE_HDRIENV_PLUGIN 1033867
#define ID_CREATE_TAREALIGHT_PLUGIN 1033868
#define ID_CREATE_SPOTLIGHT_PLUGIN 1051569
#define ID_CREATE_IESLIGHT_PLUGIN 1033869
#define ID_CREATE_SCATTER_PLUGIN 1036195
#define ID_OPEN_LIVEDB_PLUGIN 1033870
#define ID_CREATE_DIFFUSEMAT_PLUGIN 1033871
#define ID_OPEN_NODEEDITOR_PLUGIN 1033872
#define ID_STARTRENDER_PLUGIN 1033873
#define ID_CREATE_GLOSSYMAT_PLUGIN 1033893
#define ID_CREATE_SPECMAT_PLUGIN 1033894
#define ID_CREATE_MIXMAT_PLUGIN 1033895
#define ID_OPEN_HELP_WINDOW_PLUGIN 1033896
#define ID_PAUSERENDER_PLUGIN 1033954
#define ID_STOPRENDER_PLUGIN 1033955
#define ID_STOPRESET_PLUGIN 1033956
#define ID_OCTANE_CHECKUPDATE 1050444
#define ID_OPEN_OCTANE_SETTINGS 1050447
#define ID_READ_APPLY_SETTINGS 1050462
#define ID_OCTANE_APIUPDATE 1050448
#define ID_REMOVE_UNUSED_MATERIALS 1035351
#define ID_REMOVE_DUPLICATED_MATERIALS 1036468
#define ID_CREATE_VOLUME_FOG_OBJECT 1036589
#define ID_CREATE_VOLUME_VDB_OBJECT 1037329
#define ID_EXPORT_ANIM_ORBX 1037665
#define ID_OCTANE_SDKBROWSER 1038839
#define ID_CREATE_METALMAT_PLUGIN 1040116
#define ID_CREATE_HAIRMAT_PLUGIN 1054246
#define ID_CREATE_TOONMAT_PLUGIN 1040117
#define ID_CREATE_BLENDMAT_PLUGIN 1040118
#define ID_CREATE_LAYEREDMAT_PLUGIN 1053359
#define OCTANEPREFS_ID 1035356
#define OCTANE_PREFS_DIALOG_ID 1035357
#define ID_OCTANE_SUB_MATERIAL 1040369
#define ID_CREATE_UNIVERSALMAT_PLUGIN 1041569
#define ID_OCTANE_COMPOSITE_MATERIAL 1040075
#define ID_OCTANE_LAYERED_MATERIAL 1052933
#define ID_OCTANE_ROUNDEDGES 1053013
#define ID_OCTANE_CHAOS_TEXTURE 1056186
#define ID_OCTANE_CHN_MAP 1056188
#define ID_OCTANE_CHN_MERGE 1056189
#define ID_OCTANE_CHN_PICK 1056190
#define ID_OCTANE_CHN_INVERT 1056191
#define ID_OCTANE_COMPOSITE_TEX 1056192
#define ID_OCTANE_RAY_SWITCH 1056193
#define ID_OCTANE_SPOTLIGHT_DIST_TEX 1056196
#define ID_OPEN_LIGHTMANAGER 1056475
#define ID_OCTANE_COMPOSITE_TEX_LAYER 1056545
#define ID_OCTANE_HOLD_UPDATES 1056716
#define ID_OCTANE_ATTRIB_TEX 1056908
