OctaneRender 2020 for Modo [OBSOLETE]
SreckoM
face_off wrote:I have now added Linux installers for the plugin at the top of this thread.
Thanks Paul, you are the best!
jwfvr
it seems like the link for the new windows modo-13-14 studio is bringing up the linux version?
jwfvr wrote:it seems like the link for the new windows modo-13-14 studio is bringing up the linux version?
The download link has been now been fixed.
jwfvr
Im still getting the same file -
The forums reverted my change. Try again please.
jwfvr
got it! thank you!
yoshikai
Hi Paul.
Thanks for the update!
I have tried the Octane Greyscale Vertex Attribute and it works great for normal polygon objects, but the weight maps I set for curves do not load correctly.
Is there any chance in the future that the curve weight map will load correctly?
It would be very helpful if the curve weight map could be loaded correctly.
A simple scene is attached.
curve weightmap.zip
(248.21 KiB) Downloaded 351 times
I have updated the installers at the top of this thread with:
2020.2.3.171
- Color Correction->Brightness has a maximum value of 100 again
- Fixed issue where sometimes an Area or Point Light would not auto-fresh
- Fixes the issue where images could not be saved if a colorspace was specified.
yoshikai wrote:Hi Paul.
I will investigate if this can be done.
yoshikai
face_off wrote:I will investigate if this can be done
Thank you.
I appreciate it.
Return to “Foundry Modo”
