OctaneRender 2020.2 LightWave Production build 2020.2.0.4
Carlos3D
juanjgon wrote:
Carlos3D wrote:Octane 2020.2 are not work with my LightWave 2020.0.2 someone here with the some problem?
Tx guys.
CC.
What is exactly your problem?
Octane Bug.mp4
(18.73 MiB) Downloaded 3297 times
juanjgon
What a weird way to install Octane! I'm sure that you have missing Octane.dll/.dat or plugin files somewhere that are breaking the installation. Why don't you simply add the plugin from the folder where you have it in the HD, without copying it to the LightWave folders?
You should reinstall LightWave, clean the config files, and install the plugin as I've said, adding it from the Layout.
Lewis
Agreed, that is weird way of installing it.
few Things:
1. You should copy *.dll and *.dat to same folder where is plugin installed and not to LW/bin (that was old procedure, new procedure since few years is that those files can be in same folder as plugin itself = cleaner)
2. After you copy/paste all that then you go to layout and ADD plugins form Layout not just expect it will be there after copy/paste.
Additionally You might need to check Master plugins (CTRL+Q) to see if you need to remove it form there prior installing new one (through Layout Add plugins command).
cheers
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
ideart
Hello, I have installed the latest octane version and LW plugin and I can see the network nodes from the standalone but not from LW.
Invalid version 1000.14(0)
Plugin build 2020.2.0.4 v2015.3
OctAPI build 2020.2 LWSDK 2847/2847
OctDLL version 10021201
juanjgon
Do you have the Octane 2020.2.0 Standalone installed in the render nodes?
viewtopic.php?f=24&t=76901
ideart
Thank you for your quick response.
edit* Sorry I had the 2020_2_2_win.exe, all is well now.
Carlos3D
juanjgon wrote:What a weird way to install Octane! I'm sure that you have missing Octane.dll/.dat or plugin files somewhere that are breaking the installation. Why don't you simply add the plugin from the folder where you have it in the HD, without copying it to the LightWave folders?
Wowowo Tx very much Juanjo.
Ill try it right now.
Tx
Carlos3D
Lewis wrote:Agreed, that is weird way of installing it.
few Things:
cheers
Lewis my big friend thank u very much for everithing.
Ill do that now.
See u here more I hope.
Tx
Carlos3D
I want to say thank you very much to two people here in the group, first to Juanjo for always willing to help me and second to Lewis for the great help he gave me, my LW 2020.0.2 and Octane 2020.2.0.4 are now working beautifully.
Thanks Carlos Caldeira.
Lewis
Good to hear :).
Lewis
Skype - lewis3d
ICQ - 7128177
Return to “Releases”
