OctaneRender® for 3ds max® v2020.2.1 - 11.06
coilbook
HHbomb wrote:@coilbook :
If you want to see something in octane you need to add a "Mesh" operator in your event. With "Triangle Mesh" and uncheck Render only.
If you want to render a lot of instanced objects you must : (see pict)
- add "Mesh" operator and check "render only" if there is really lot of object and it slow down max viewport.
- check "enable Particle interface" in tyflow settings.
Works very well.
Question to Paride :
When we need to use a gradient to color tyflow particle depending to its age, octane render gradient don't work, but max's plugged in a rgbImage node is working ?
Thank you!
ramone163
I need to "Rebuild scene" every time I want too see Procedural texture (in this case Marble texture) "3d transformation" changes.
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
samsue
that's great! Now converting material by selected object works too!
Thanks :D
HHbomb
@samsue : since a long time now :mrgreen:
paride4331
ramone163 wrote:I need to "Rebuild scene" every time I want too see Procedural texture (in this case Marble texture) "3d transformation" changes.
Hi ramone163,
it's an SDK issue, should be solved with the next release 2020.2.2.
paride4331
coilbook wrote:Second problem TYFLOW cannot be rendered in 2020.2 octane. 2019 works fine
the scene is attached
Hi coilbook,
Developers are looking for a workaround about it.
paride4331
coilbook wrote:Hi Paride,
Do you know how to create a bright narrow projector light? I tried IES and regular disk lights but nothing works
And get rid of noise around the projector. We have octane atmospherics
PS I need narrow volume light. Can a new octane version create volume lights and how?
Hi coilbook,
volumetric spotlight?
viewtopic.php?f=25&t=75341&p=386578&hilit=+spot#p386578
samsue
HHbomb wrote:@samsue : since a long time now :mrgreen:
hahahaha ... there are some things that I avoid using, so as not to get frustrated... then I stop using.
but hey .... good to see that it was solved.
I'm waiting to use the AOV...
samsue
bug?
mbetke
Its SDK bug. Was discussed here in the thread :)
PURE3D Visualisierungen
Return to “Releases”
