All I can say for now is that this is our #1 priority and we'll do our best to implement it in the next build! I'll keep you posted, but consider that I totally get your "desperation" about it, because yes, Alembic is extremely important!Rikk The Gaijin wrote:@linograndi can you give me an estimate of when this will support Alembic? I desperately need a software to edit alembic animations.
Sculptron 1.0
- linograndiotoy
- linograndiotoy
Not yet, but supporting a background image sequence/movie is very important and something we're totally considering to implement!ChrisSmith wrote:This looks great.
Does Sculptron has the option to load image sequence?.., that would be very useful for vfx where you need full precision and also for reference.
- Rikk The Gaijin
Thank you Lino, you can reach me on Discord (I've left you a msg on the official channel), I can do some beta testing too if you need.linograndiotoy wrote:All I can say for now is that this is our #1 priority and we'll do our best to implement it in the next build! I'll keep you posted, but consider that I totally get your "desperation" about it, because yes, Alembic is extremely important!Rikk The Gaijin wrote:@linograndi can you give me an estimate of when this will support Alembic? I desperately need a software to edit alembic animations.
Yes, it is on the shop page for $10/month without Octane.rs3d wrote:Will it be possible to buy Sculptron without Octane?
I think this is a product that is fully render agnostic...
Same issue here.tiagoffcruz wrote:Artefacts everywhere, i already tried to install an older Gpu driver version but it didn't solved any of the problems.
I detected three main render problems so far, the PBR material is really dark when applied to the mesh, switching between matcaps causes most of the artfacts and the initial grid axis stay "Frozen Printed" on the screen all the time.
My machine: Ryzen 5 1600, 32GB RAM, GPU RX580
AMD Ryzen Laptop specs: AMD Ryzen 7 7800H, 16GB RAM, GPU NVIDIA GeForce RTX 4090 or RTX 4080 laptop.
Any help? Thanks.
- linograndiotoy
Be sure to be using the latest NVIDIA drivers and Win10 update.bellaot wrote:Same issue here.tiagoffcruz wrote:Artefacts everywhere, i already tried to install an older Gpu driver version but it didn't solved any of the problems.
AMD Ryzen Laptop specs: AMD Ryzen 7 5800H, 16GB RAM, GPU NVIDIA GeForce RTX 3070.
Any help? Thanks.
For example I am using 1080 Ti and also have this problem. TaskManager empty after starting Sculptron. Please fix this. A lot of people have this problem.linograndiotoy wrote:Thank you for your patience!wavesoflight wrote:All done. Cheers for trying to help out Lino.linograndiotoy wrote:Please send an email to [email protected] specifying your configuration and the subscription you're using!
- linograndiotoy
